    I made a back up of a commercial Blu Ray movie using AnydvdHD then I shrank it with BD Rebuilder. I then want to make a DVD with subtitles.
    How can I add the subtitles?
    I have the following softs!!
    AnyDVDHD
    BD Rebuilder
    tsMuxer
    Nero8
    I have already made a DVD with Nero ( that played well on my BDP Panasonic BD30) but it doesnt make or add any subtitles to the DVD, in reality it doesnt convert the files from tsMuxer if there is a subtitle there!!
    So I am doing a DVD quite well with Nero 8 but without the subs that is good when you donīt need subs and in this case I remove the subs in tsMuxer before converting to DVD with Nero!!
    But now I want to make a DVD Movie with the subtitles.
    How to do??
    Thanks in advance!!
    So you want to convert the blu-ray to a standard dvd-video with subtitles?
    Or are you just burning the shrinked blu-ray on dvd media? Then should the subtitle work. Do not use Nero to convert anything then...
    Baldrick wrote!!!
    First many thanks for your answer!!!
    Yes that is the case!!!
    I want to convert the blu-ray to a standard dvd-video with subtitles.
    If possible with free soft!!
    Thanks!!!
    Try extract the subtitles from the blu-ray using eac3to. Then convert the subtitles to sub/idx using bdsup2sub, and last try add the m2ts and sub/idx in nero if possible. Or use convertxtodvd or dvd flick(free).
    Thanks again Baldrick!!
    It looks to me that DVD Flick could do the trick!!!
    I will study it first and perhaps to give it a try!!!
    My doubt is if it will convert the Brazilian Portuguese subs or that doesnt matter the language???
  1. Once your Blu-Ray is ripped, will it play on WDTV?
    By siratfus in forum Blu-ray Ripping
    Last Post: 14th Sep 2011, 10:43
  2. Help, can't convert or view VC-1 files ripped from Blu Ray
    By Y2Bogus in forum Video Conversion
    Last Post: 12th Jun 2009, 06:29
  3. Forced Subtitles in M2TS - Blu-ray Ripped to HDD
    By saber001 in forum Blu-ray Ripping
    Last Post: 23rd Mar 2009, 07:14
  4. BLU-RAY Ripped
    By pensioner in forum Newbie / General discussions
    Last Post: 11th Feb 2009, 23:37
  5. Burning Blu Ray from ripped Blu Ray
    By ppurdue in forum Blu-ray Ripping
    Last Post: 15th Oct 2008, 20:51
About   Advertise   Forum   RSS Feeds   Statistics   Tools
