    2 questions.
    1. I "seem to" be getting spotty performance from the pro version. I say "Seem to" because I ran the free version a bit but really never did any timed testing. But I was expecting a real boast. Here is where I'm confused and wondering if something else is the issue. This is not a speed demon machine 1.7Ghz with 1Gmemory. However, the processor is not pegged (in fact at times it is at 10%) nor does it look like it is out of memory. However, the application is very unreponsive to requests to expand or minimize or move it and the machine is overall sluggish. Any thoughts/suggestions? I am only converting 1 VOB file - the main move - to MPG in the process.
    2. Is it possible - once I figure out my other performance issue - to run muliple copies of the product? Is it wise to do so?
    Thanks. HTBH.
    I have found that, if you look at the VOB2MPG.exe in the processes list of the Task Manager and right-click on it and examine the priority, it is set to Low. Be elevating it to Normal I have seen an improvement in responsiveness but am still too new to the program to say for certain if it improves its overall performance. Theoretically it should.
    M. R. Murry
    A program like VOB2MPG is I/O limited because it is mostly hard drive activity (it is waiting for the hard drive most of the time). Converting VOB files on one drive to MPG files on another drive will increase throughput. Changing it's process priority will not help unless your CPU is busy doing something else (like encoding a video).
  4. Member ChrissyBoy's Avatar
    CPU @ "LOW Priority" is so that other programs can share in the CPU if required. If nothing else needs the CPU - a process at "low" priority will use all it needs. i.e. VOB2MPG will yield to other processes IF required, but not otherwise.
  1. VOB2MPG Version 2 on Windows 7?
    By Reading Bug in forum SVCD2DVD & VOB2MPG
    Last Post: 25th Jan 2010, 20:20
  2. VOB2MPG Pro preview not working & conversion slow
    By MDJH in forum SVCD2DVD & VOB2MPG
    Last Post: 22nd Sep 2009, 15:01
  3. Replies: 3
    Last Post: 19th Dec 2008, 21:22
  4. No mpg file after running VOB2MPG
    By DrScud in forum Newbie / General discussions
    Last Post: 13th Dec 2005, 13:35
  5. Multiple AVI to DVD w/DivxtoDVD & DVD-Lab Pro...
    By iNfEk in forum Newbie / General discussions
    Last Post: 3rd Nov 2005, 18:44
About   Advertise   Forum   RSS Feeds   Statistics   Tools
