VideoHelp.com Forum
    I'm running VOB2MPGPro 3.0.0100, and I have a couple of problems. The first one is the video doesn't show in the preview window. I hear audio, but no video.
    The second problem is, while I'm listening to the audio, if I attempt to resize the application by dragging an edge, I get the following error:
    Version: VOB2MPG PRO
    Build: 3.0.0100
    Type: System.Runtime.InteropServices.COMException
    Source: DirectShowLib-2005
    Message: One or more arguments are invalid
    InnerException:
    StackTrace: at DirectShowLib.DsError.ThrowExceptionForHR(Int32 hr)
    at VOB2MPG_PRO.DVDPlayerCtl.ResizeVideoWindow()
    at VOB2MPG_PRO.DVDPlayerCtl.DVDPlayerCtl_Resize(Objec t sender, EventArgs e)
    at System.Windows.Forms.Control.OnResize(EventArgs e)
    at System.Windows.Forms.UserControl.OnResize(EventArg s e)
    at System.Windows.Forms.Control.OnSizeChanged(EventAr gs e)
    at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
    at System.Windows.Forms.Control.UpdateBounds()
    at System.Windows.Forms.Control.WmWindowPosChanged(Me ssage& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
    at System.Windows.Forms.UserControl.WndProc(Message& m)
    at VOB2MPG_PRO.DVDPlayerCtl.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    Please help. Thank you.
  2. Member ChrissyBoy's Avatar
    What OS are you running?
    Thank you for responding. I'm running Windows Server 2008 Datacenter.
  4. Member ChrissyBoy's Avatar
    Wow! ok..... Can you try installing ffdshow - perhaps that will give you the video playback?
    I have FFDShow installed. Something else I have installed must have included it. Is there some way I need to configure it? I admit, I'm new to working with video, so please forgive my lack of knowledge.
  6. Member ChrissyBoy's Avatar
    Can you take a look at http://forum.videohelp.com/topic373702.html to see if that helps. Failing that i will try to resolve you both at the same time!
    I am having the same trouble but I am new so don't know if a fix was found or where to post my problem. Please help, I don't want to abandon this yet. Thanks for helping a new idiot. LTBREHMER
  1. VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
    By Rich_A in forum SVCD2DVD & VOB2MPG
    Last Post: 2nd May 2011, 15:06
  2. Unable to install VOB2MPG or VOB2MPG PRO
    By tooc in forum SVCD2DVD & VOB2MPG
    Last Post: 28th Mar 2010, 00:53
  3. vob2mpg error: Could not get interfaces No such interface supported
    By Lowell in forum Newbie / General discussions
    Last Post: 2nd Dec 2009, 23:48
  4. VOB2MPG Pro V3.0.0024 error
    By SWBisbee in forum Newbie / General discussions
    Last Post: 3rd May 2009, 16:23
  5. Error when launching VOB2MPG 3 PRO in Vista Ultimate 64bit
    By ghostwulf in forum SVCD2DVD & VOB2MPG
    Last Post: 20th Mar 2009, 05:28
