VideoHelp.com Forum
    Tried google this but I only got more confused. I'm noob at encoding.
    I got a 1280x720 (HD) h264 file and i want to add hardcoded subtitles to it. I know i must re-encode, but I don't know any good programs for this task. Anyone got some recommendations of programs to use (or maybe a link to some tutorial?). Help!
    xvid4psp, load video and load subtitle, choose a profile, convert. done.
    thanks Baldrick. However, when I've encoded (used mkv container), I ended up with no audio (i selected copy). I guess i'll give it a try encoding the audio too, but I don't know which option gives the best quality. Help?
    http://img36.imageshack.us/img36/5971/audiol.jpg
    Higher bitrate will give you better quality, Q100 in that list
    What container is your original file in?
    You shouldn't have to re-encode the audio and lose quality
    Did you already hardsub the video?
    original file is .mp4. I tried to select to encode into mp4 first, but the program froze at 98% when muxing, so I went with mkv.
    I did hardsub it in mkv container. Great quality and all, but no sound as I said
    Use yamb to extract original audio from mp4
    mkvtoolnix to add the audio to your hardsubbed mkv
    thanks, will try that!
  1. Replies: 7
    Last Post: 4th Jun 2010, 18:08
  2. extracting timecodes from hardcoded subs
    By quzma in forum Subtitle
    Last Post: 2nd Jan 2010, 15:26
  3. Mkv to mp4 with hardcoded subs on Mac
    By Mauserman in forum Mac
    Last Post: 30th Aug 2009, 03:19
  4. .ts file convert to h264/aac with hardcoded subtitles
    By akiraku in forum Video Conversion
    Last Post: 25th Apr 2009, 08:49
  5. Replies: 3
    Last Post: 6th Jun 2007, 19:29
