I was looking to buy a bd burner on Amazon.com. This item requires a PC with dual core, 1gd memory, ATI HD 2000, Nvidia video card... Meanwhile other bd burners doesn't even mention about PC reqiurements. My question is what kind of computer I need to have? Thank you
The PC requirements are to run the included software package. You need a decent processor, ram, and video card to play BD discs and to edit HD video.
At the minimum a dual core cpu, 2GB of DDR2 ram and a HD video card should be considered.
If I just want to put multiple dvd movies on a bd disc, I definitely need a bd burner. Do I still need a HD video card? If so can you name some hd video cards? Thankyou.
You don't need an HD videocard to author but you do to output to an HDTV, I would consider these:
http://www.newegg.com/Product/Produc...82E16814121320
http://www.newegg.com/Product/Produc...82E16814102829
If you can afford a new PC I would wait one month to get one with Win7, I also read Apple is coming out with a Mac with Blu-ray.Having problems ripping a DVD? Read my guide
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 23:23 -
DVD-Video Audio Spec. (Dolby 2.0) vs. Blu-Ray Disc Audio Spec. (Dolby 2.0)
By Disco Makberto in forum AudioReplies: 5Last Post: 31st May 2008, 15:30 -
Replacement burner for low-spec PC
By Ionakana in forum DVD & Blu-ray WritersReplies: 3Last Post: 2nd Jun 2005, 12:19 -
dvd-writer: hardware spec needed
By jeremypps in forum DVD & Blu-ray WritersReplies: 0Last Post: 30th Oct 2002, 07:06 -
Question regarding VCD 2.0 structure - VCDImager spec needed
By PigOnWing in forum Authoring (VCD/SVCD)Replies: 2Last Post: 18th Sep 2002, 03:51
Statistics
Newest guides
Latest tool updates
New media comments
