I have a DVD given to me of a performance I did on a ship. Unfortunately they did not have any effects on the audio so it sounds terrible. I would like to rip out the audio track, run it through a reverb unit, then add it back to the original video of the DVD so it sounds like it should. There is only 1 chapter in the original and I would also like to add chapters so I can find other performers without having to go though the entire DVD. I will gladly purchase any program, s, that will accomplish this. Thanks in advance..
Results 1 to 11 of 11
Use pgcdemux to demultiplex the video and audio tracks from the dvd. Fix the audio file. Last author a new dvd from the old video file and the new file using for example Tmpgenc Authoring works or Gui for DVD Author(free).
Thanks for the quick reply. Quick question sir, will the audio file be a wav or mp3 file once it is demultiplexed?
DVDs don't use MP3.Originally Posted by arcelton
Either Wave or AC3, possibly MP2.
I successfully changed the audio file and have the right effects on it. It is now an mp3 file. I need to get it back to an mpa since thats what the file was after demuxing. I see lots of programs that say the convert mp3 to mpa but dont see that option. IS mpa known by a different name?
"mpa" is a non-specific suffix. Some programs give it to all the audio files they create, regardless of actual formatOriginally Posted by arcelton
Anyway, for a DVD you need AC3.
As I said in my last post.
I use Xvid4PSP 5.03 for my audio work. It will convert your mp3 to ac3 (among others) and normalize while doing so. A somewhat confusing (at first) app that does many things well.
i finally have a good ac3 file that I now need to join to my video file to create a file i can watch and listen to on media player. and i would also like to make a dvd out of it. My problem is finding a program that merges the audio and video files back together. kinda the reverse of demuxing. any suggestions?
That's called "muxing" (multiplexing").Originally Posted by arcelton
See the tools page: http://www.videohelp.com/tools
In particular: http://www.videohelp.com/tools/secti...e-multiplexers
ImagoMPEG-Muxer is good if you just want to make an MPEG you can watch on your PC.
Making a DVD is a bit more complex, that's called "Authoring".
http://www.videohelp.com/tools/sections/authoring-dvd
You can make a very simple DVD, no menu, from MPEG video + AC3 audio using ReJig.
If you're more ambitious, GuiforDVDAuthor lets you add menus and many other features.
You'll then need a burning app to burn the resulting files (a VIDEO_TS fileset) to DVD, use ImgBurn.
Actually, some media players will combine separate video and audio files on the fly and play them together, but they usually can't seek and go out of sync easily. But useful for a quick preview.
dear AlanHK,will gui fo rdvd author accept video and audio seperately or it will accept only the multiplexed material?? thanks have a nice day.
Either. But preferable to give it separate files, it will mux them itself.Originally Posted by sumeshkri
What is the easiest way to add or replace existing audio DVD sound track
By pwangdel in forum Authoring (DVD)Replies: 18Last Post: 2nd May 2011, 01:10 -
Add audio-track to DVD WITHOUT re-authoring
By vk_dk in forum DVD RippingReplies: 1Last Post: 14th May 2010, 19:57 -
I want to add an audio track to a DVD.
By Nagashi in forum Authoring (DVD)Replies: 7Last Post: 14th Apr 2010, 20:39 -
I want to add an audio track to an existing DVD
By gouletjo in forum Authoring (DVD)Replies: 1Last Post: 31st Jan 2010, 16:21 -
Can you add a second language audio track on DVD workshop 2
By uncle mikie in forum AudioReplies: 1Last Post: 14th Jan 2010, 23:22
