VideoHelp.com Forum
Results 1 to 9 of 9
  1. Hello,
    as it is stated in the title, econding always stops after few minutes. Here is the log
    E:\>"E:\download\00_VIDEO_software\RipBot264\tools\x264\x264_x86.exe" "E:\temp\RipBot264temp\job1\job1.avs" --pass 1 --bitrate 7212 --stats "E:\temp\RipBot264temp\job1\job1.stats" --fps 24 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "E:\temp\RipBot264temp\video.264"
    avis [info]: 1920x1080 @ 24.00 fps (187083 frames)
    x264 [info]: using SAR=1/1
    x264 [warning]: VBV bitrate (25000) > level limit (20000)
    x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
    x264 [info]: profile Main, level 4.0
    Assertion failed: dpb_output_delay < pow( 2, sps->vui.nal_hrd_parameters.i_dpb_output_delay_lengt h ), file encoder/set.c, line 652
    This application has requested the Runtime to terminate it in an unusual way.
    Please contact the application's support team for more information.
    E:\>"E:\download\00_VIDEO_software\RipBot264\tools \x264\x264_x86.exe" "E:\temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 7212 --stats "E:\temp\RipBot264temp\job1\job1.stats" --fps 24 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "E:\temp\RipBot264temp\video.264"
    x264 [error]: ratecontrol_init: can't open stats file
    x264 [error]: x264_encoder_open failed
    E:\>"E:\download\00_VIDEO_software\RipBot264\tools \mkvtoolnix\mkvmerge.exe" -o "E:\download\00_VIDEO_software\dune\Stargate DC 1994 BluRay 1080p DTS x264 dxva-EuReKA.mkv" --title "Stargate DC 1994 BluRay 1080p DTS x264 dxva-EuReKA" --default-duration 0:24fps -d 0 -A -S "E:\temp\RipBot264temp\video.264" --language 0:eng --sync 0:0 -a 0 -D -S "E:\temp\RipBot264temp\job1\audio.1.dts" --chapters "E:\temp\RipBot264temp\job1\chapters.txt"
    mkvmerge v2.9.0 ('Moanin'') built on May 22 2009 17:46:23
    Error: The file 'E:\temp\RipBot264temp\video.264' has unknown type. Please have a look at the supported file types ('mkvmerge --list-types') and contact the author Moritz Bunkus <moritz@bunkus.org> if your file type is supported but not recognized properly.
    Elapsed Time: 00h:04m:44s
    Can somebody tell me what is wrong ?
    Thanks.
    Does it happen with all video sources?
    What is your video source? A blu-ray that you decrypted first or running anydvd?
    And try open the job1.avs and see if you can play it windows media player or mpc.
  3. source is mkv blue ray rip
    job1.avs playing ok in wmp
    tried 2 different mkv sources it is the same, that means from MKV to MKV.
    I used before older version of ripbot, and it was OK
  4. Mod Neophyte Super Moderator redwudz's Avatar
    I had the exact same error with V1.14.4. Tried V1.13.3 and it worked fine. The rest of my error is:
    x264 [error] ratecontrol_init: cant open stats file
    x264 [error] x264_encoder_open failed.
    That's the second time that V1.14.4 failed on me, so I just went back to the earlier version.
    I'm having the same issue (same exact error) as the OP with all of my encoding attempts. I've ripped my bluray discs to my HD using AnyDVD HD 6.5.8.7 (newest version afaik). My job1.avs file will also open and play properly in WMP.
    Here's my currently installed versions:
    RipBot264 v1.14.4 (previously had the same problem with 14.3, updating to 14.4 didn't change anything)
    ffdshow rev 3092, 2009/09/27
    Haali media splitter 1.9.42.1
    Avisynth 2.5
  6. Mod Neophyte Super Moderator redwudz's Avatar
    Try an earlier version and see if that works. I use 1.13.x and 1.12.x and neither seem to have that problem. The program is just a .exe, so doesn't need to be installed anyway. I don't know if it's a bug with the newer versions or RipBot or just my version choices of the required peripheral programs.
  7. Tried V1.13.3 and it worked fine, so that is a solution, strange thou
    thanks guys.
    Yah, I downloaded 1.14.1 and so far it seems to be working fine; although, I'm only 15% through the first pass atm, but I wasn't ever getting past 2% using two newest versions.
    Try this:
    32 bit http://jeeb.fiveforty.jp/x264/1281/x264.exe
    64 bit http://jeeb.fiveforty.jp/x264/1281_x64/x264.exe
    Make sure to overwrite the one that's already in there.
  1. RipBot Encoding Wrong Language
    By andy6590 in forum Blu-ray Ripping
    Last Post: 1st Apr 2011, 15:20
  2. Ripbot problem please help
    By XxL3tHaL LsDxX in forum Video Conversion
    Last Post: 18th Dec 2010, 00:42
  3. Encoding Blu-ray to Mp4 with RipBot Trouble
    By F.Garvin in forum Blu-ray Ripping
    Last Post: 2nd Nov 2010, 22:30
  4. Ripbot sound problem
    By ratch3t in forum Blu-ray Ripping
    Last Post: 20th Dec 2008, 08:26
  5. can you speed up encoding with ripbot x264
    By zerocoool in forum Video Conversion
    Last Post: 26th May 2008, 21:07
