I'll start a copy - 3GB worth of 30MB files from one SATA drive to another identical SATA drive inside the same PC.
Performance starts out at 30MB/sec transfer rate, then as the copying progresses it drops down to 1.4MB/sec
CPU usage hovers at only 3%
Machine has 8GB RAM (only 814 in use). No other processes running. No antivirus protection installed.
Then I'll run the copy again and it flies on through at 100MB/sec
EDIT: I'm thinking it has to do with NTFS file compression, which I've enabled on one of the drives.
"Quality is cool, but don't forget... Content is King!"
Sounds like a driver problem for your sata-ide drivers,are they nvidia drivers installed?My sata to sata copies at 60mbytes with no slowdown.
Ben Johnson-I didnt take any stereos!
thx, yes it's an nvidia mobo.
Best to install the microsoft drivers for your ide controller,nvidia ide drivers are known to cause those problems.
copying streaming
By ruthann in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2011, 11:14 -
dvd copying
By ruthann in forum DVD RippingReplies: 9Last Post: 26th May 2011, 17:57 -
Copying AVCHD
By Bigbaddaboom in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 1st Apr 2010, 23:53 -
copying
By merc68 in forum DVD RippingReplies: 13Last Post: 7th Nov 2009, 17:26 -
copying????
By bamf321123 in forum DVD RippingReplies: 1Last Post: 23rd Jun 2007, 06:39
Statistics
Newest guides
Latest tool updates
New media comments
