VideoHelp.com Forum
Thread: MTS Joiner
  1. Member ChrissyBoy's Avatar
    MTS Joiner: First of several simple "Applets" which will be bolted onto VOB2MPG PRO...
    All it is is a simple front end to tsMuxeR. However you can drag and drop *.mts files, preview them, reorder them and then join them in a very straightforward way...
    Usage:
    Currently sucessfully used for joining Panasonic TZ7 and Panasonic ZS3 AVCHD-Lite MTS files... There may be many other uses.
    Availiable in VOB2MPG PRO build 3.0.0100 onward.
  2. hey chrissy - for some reason malwarebytes has tagged vob2mpgpro.com's ip 98.124.198.1 as malicious and is blocking it. svcd2dvd.com is fine.
  3. Member ChrissyBoy's Avatar
    Nice.... I will investigate! Thanks for the heads-up.
  4. Member MJ Peg's Avatar
    That look good, thanks - I'm trying to join mts files
    a) would there ever be a standalone version, or do I have to learn how to use Vob2Mpg?
    b) will the large joined.mts result be better than the one from TsSplitter which ended up either unplayable all the way through, or glitchy, or almost correct but frozen/mucked-up around the joins?
    i.e. a straight combination of the files doesn't seem to really cut it - it really needs to construct a genuine video bitstream as if it was all one take.
  5. Member ChrissyBoy's Avatar
    a: It is standalone but launched via vob2mpg pro
    b: works fine for me.... play back is seamless.
    If you would like to kick its tyres - email me and i will send you a copy.... would be good to hear your opinion.
  6. Member MJ Peg's Avatar
    OK, I've PM-ed you... many thanks
  7. chrissyboy - any luck convincing malwarebytes the vob2mpgpro.com site isn't evil? they have a forum you can use to talk to them about it.
  1. MPEG Joiner ?
    By ashe09 in forum Video Conversion
    Last Post: 12th Oct 2011, 03:14
  2. Video to MTS Converter, Not MTS to other videos
    By dzsoul in forum Video Conversion
    Last Post: 18th Apr 2011, 10:16
  3. Replies: 11
    Last Post: 2nd Mar 2010, 05:56
  4. HD Cam wrote .mts files to my flash card but put in another cam still mts
    By Onceler2 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 15th Dec 2009, 06:15
  5. RM Joiner
    By nic3 in forum Editing
    Last Post: 8th Sep 2009, 05:24
