    I have some videos of a meteor that were taken from a security camera. Its a Pelco security system. The avi files require a special codec PLV1. I have the codec downloaded and can only view the videos on windows, and only in certain players. I haven't been able to get some of the converters and software I've downloaded to work with the codec, even though I can view the videos in windows media player.
    Ultimately I need to
    1) turn the videos into a common format that doesn't require the codec.
    2) dump all of the frames in the videos to jpg files.
    If anyone has any suggestions or could help me do this i would really be greatul. I'd also be interested to know if you can get these videos to play and if you can get them to play convert in your software.
    Here are the videos and links to download the codecs,
    http://www.mikesastrophotos.com/traj...on-meteor.html
    They are pretty cool videos of a fireball meteor that recently crashed in Pennsylvania.
    Thanks,
    Have you tried avisynth? Install avisynth and make video.avs file with just
    DirectShowSource("c:\folder\video.avi")
    Then open the video.avs in virtualdub.
    i will give this a try thanks.
    Cool! DirectShowSource(), VirtualDub, Neat Video, Xvid:
    meteor.avi
    thanks jagabo, but when i go to play this on a mac in quicktime, I get quicktime component required.
    jagabo used xvid/avi which isn't natively supported on mac
    You could use vlc which is crossplatform (pc, mac, linux)
    Or you could encode to h.264/aac/mp4
    He did it using avisynth, so it might be difficult for you to do conversion if you only have access to mac
    VCD MPEG1: meteor.mpg Looks worse though.
    Thanks I can view the MPEG 1 video. I have access to the PC I just haven't been able to get it work yet. will try again with these tools. thanks.
  1. Replies: 3
    Last Post: 20th Jan 2009, 17:22
  2. Replies: 1
    Last Post: 13th Jan 2009, 23:13
  3. Sony Vegas -- Issues With Videos
    By wrathofnero in forum Newbie / General discussions
    Last Post: 30th Jun 2007, 22:55
  4. Automated batch conversion of MPEG2 videos to Zune videos
    By dlflannery in forum Video Conversion
    Last Post: 12th Jan 2007, 10:59
About   Advertise   Forum   RSS Feeds   Statistics   Tools
