Here's a short blurb on my problem and goal. I use uShare running on a Ubuntu 9.04 Server to stream video to my XBox 360. My DVD collection has been converted to XviD using mencoder, and it works great. I'd like to start saving my videos in h.264 format especially considering I'll be geting some Blu-ray discs soon. XviD streaming of 1080p content doesn't work well. Microsoft specifications for streaming mpeg4 to the XBox 360 is 1024x768 @ 5Mbps, and 1080p video in mpeg4 doesn't stream well with high bitrates. The XBox 360 supports H.264 @ 15Mbps and that should work much better for streaming 1080p video to it. I've performed testing with a few discs and pre-encoded videos. I've tried putting the video on flash media and streaming through uShare. All completely failing to play on the XBox 360.
My observation has been that when the codec and container frame-rate do not match the movie will not play on the XBox 360 (mpeg4). This is what I believe is happening with my H.264 conversions. ffmpeg information on videos shows that when I see the following messages the video is uplayable on the console. I'm only including the part of the output which I think is relevant.
When I see the tbr, tbn, and tbc match up then the videos work. The following is the video stream info (ffmpeg) from a console playable video.Code:Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1) -> 25.00 (25/1) Stream #0.0: Video: mpeg4, yuv420p, 576x432 [PAR 1:1 DAR 4:3], 25 tbr, 1200 tbn, 50 tbc
All of my attempts at H.264 output has yielded videos with this ffmpeg information:Code:Stream #0.0: Video: mpeg4, yuv420p, 576x432 [PAR 1:1 DAR 4:3], 25 tbr, 25 tbn, 25 tbc
So, the container and the codec frame rate do not match. I tried putting the H.264 stream inside a mp4 container using MP4Box. But, that didn't work either.Code:Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1) -> 25.00 (25/1) Stream #0.0(und): Video: h264, yuv420p, 720x576, 25 tbr, 25 tbn, 50 tbc
How can I get the tbr, tbn, tbc, container frame rate, and codec frame rate values to match? It's been driving me insane.
Results 1 to 1 of 1
Problem: Playing HD h.264 file on Xbox 360
By TOMillr in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Apr 2011, 08:04 -
How do I make a H.264 .TS File play normally on xbox 360 extender?
By bubbrubb in forum Video ConversionReplies: 2Last Post: 6th Feb 2010, 13:53 -
Lots of question regarding conversions, bit rate, Xbox 360...
By walterdavid in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 22:06 -
Xbox 360 h.264 HD video playing back skippy - Need Help
By cbstryker in forum Video ConversionReplies: 2Last Post: 21st Dec 2008, 01:24 -
What's the Best Bitrate for Converting DVDs to .264 MP4 files for xbox 360?
By keyed in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 02:04
