VideoHelp.com Forum
Results 1 to 9 of 9
    i have installed the binaries and intalled the software properly, or so i think, but when i try to encode a video it makes a video file with no data (zero bytes) what am i doing wrong?? please and thanxs.
    -Se0r
    Moving you to our ffmpegx section.
    Does it happen with all your video files?
  3. Explorer Case's Avatar
    After trying to encode a file, click the blue "i" in the ffmpegX Progress window. This will bring up a new window with the Process Information. It is like a log of what ffmpegX was trying to do. It will also contain any error messages, if an error happened. Please post that information here for examination.
    Same here >
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Thu Sep 24 17:35:50 CEST 2009
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/maxtor250gb/Desktop/test.mov':
    Duration: 00:00:29.2, start: 0.000000, bitrate: 161084 kb/s
    Stream #0.0(eng): Audio: aac, 44100 Hz, stereo
    Stream #0.1(eng), 24.00 fps(r): Video: qtrle, rgb24, 1910x917
    Codec type mismatch for mapping #0.0 -> #0.0
    My System:
    Apple Mac Pro Intel
    OSX 10.5.8
  5. Explorer Case's Avatar
    The audio stream is listed before the video stream in your file. If ffmpeg isn't told about that, it expects it the other way around (video before audio).
    Set the "Invert mapping" checkbox in the Audio tab. Now you won't get a "Codec type mismatch for mapping"-error for this file anymore.
    Hi,
    now it works ! Thanks so much !
    Encoding started on Thu Sep 24 18:15:39 CEST 2009
    Output #0, flv, to '/Users/maxtor250gb/Desktop/test.mov.ff.flv':
    Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 320x240, q=2-15, 200 kb/s
    Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0 [sync #0.0]
    Stream #0.0 -> #0.1 [sync #0.1]
    video:404kB audio:200kB global headers:0kB muxing overhead 105.957644%
    bench: utime=4.271s
    /Applications/ffmpegX.app//Contents/Resources/flvtool2:2:in `require': no such file to load -- flvtool2 (LoadError)
    from /Applications/ffmpegX.app//Contents/Resources/flvtool2:2
    well ive been trying to encode to all the file types and i always get the same result, one second encoding and an empty file, this is what i generally get in the blue i window:
    Thu Sep 24 12:26:53 GMT+4 2009
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/seormalpez/Desktop/burningman.mp4':
    Duration: 00:00:18.9, start: 0.000000, bitrate: 627 kb/s
    Stream #0.0(und): Audio: aac, 44100 Hz, stereo
    Stream #0.1(und), 29.97 fps(r): Video: h264, yuv420p, 480x320
  8. Explorer Case's Avatar
  9. Unless you are an expert or a glutton for punishment, I suggest you try MPEG Streamclip instead. It is much more usable.
  1. Not able to encode realvideo with ffmpegX on MacOS SnowLeopard
    By oicram in forum ffmpegX general discussion
    Last Post: 10th May 2011, 14:55
  2. FFMPEGX won't encode!
    By Kalasin in forum ffmpegX general discussion
    Last Post: 26th Jul 2009, 11:02
  3. What encode does FFMPEGX use for FLV?
    By pieman1968 in forum ffmpegX general discussion
    Last Post: 3rd Apr 2009, 13:16
  4. FFmpegX can't encode vobs
    By sgee34 in forum ffmpegX general discussion
    Last Post: 15th Jun 2008, 17:07
  5. Does ffmpegX encode all the metadata information?
    By ramo53 in forum ffmpegX general discussion
    Last Post: 19th Jul 2007, 20:22
