Hello
Im looking to buy a DVD/VCR recorder from KMart. Its a Magnavox ZV427MG9.
Has anyone used this product? I read some reviews online and most of them were good.
I want to use this product to record tv shows both on vhs and recordable dvds, but my problem is that the cable company uses a coaxial cable to connect to my tv and there isnt a rf output on the dvd recorder. Can anyone tell me what else Id have to buy to get the setup to work?
Tks.
Results 1 to 11 of 11
DVD recorders don't output through the RF anyway. You need to use the line outputs. If the TV doesn't have line inputs, you need an RF modulator. You'll need a cable box too.
I checked out a RF modulator and ill be getting one, but what would I use the cable box for?
Don't buy Magnavox/Phillips (Period). If the DVD Recorder is anything like their TVs, You will be buying another DVD Recorder in a year. You've been warned.
It Started In Texas
Most reviewers that leave reviews on DVD recorders are misguided. They don't know much, and they are too accepting of poor quality image/audio, but overly critical of non-important aspects.
For example,
I don't pick a car based on tire pressure -- I test how it drives.
The 0-60 test is also stupid, who does that in real life?
Magazines and sites reviewing often have the problem. Or worse, they're trying to be too nice when the product is utter crap.
For an honest look at recorders, read this:
http://www.digitalfaq.com/reviews/dvd-recorders.htm
No BS, emphasis on visual recording quality.Answers to Common Video Questions:
Best blank discs Timebase Corrector FAQ Best VCR for capturing Help restoring video
The recorder doesn't have a tuner. You need the cable box to tune the channels.
jr.com has for $159, free shipping a
Magnavox H2160MW9-RB HDD & DVD Recorder with Digital Tuner - REFURBISHED
Records up to 180hrs. onto 160GB HDD / Watch, Forward, Rewind or Freeze Live TV while Recording / 1080p up conversion / HDMI output / ATSC/NTSC Tuner
Includes RF output. No VCR.
While I wouldn't buy much of what's offered by Magnavox or it's parent company Funai, the 2160a is a decent recorder, I'd suggest it.
It does have a bug where you can't finalize or format DVDs if you've got a scheduled recording in it's event timer but otherwise it's a decent machine.
Note even though the 2160a has a RF output it's ONLY for RF passthru, like all DVDRs only(not some combos) it does NOT have a RF modulator(needed to hook it up to a older RF only TV).
The 2160a has a CLEAR QAM tuner, it will only get what a digital TV(without a CC) will get. Your cable box may get more channels than a clear QAM device like the 2160a is able to tune.
RF modulators are sold at places like Radio Shack or even Walmart. Expect to pay ~$20.
The RF output on the recorder from JR would just be a pass through. I've never seen or heard of a DVD recorder that outputs through the RF.
Got beat to that one. Oh well.
I had a Centrios DVD recorder that did RF coax output. Only one I ever saw.
Never say never
I also had a Centrios(for 1 day, I returned it due to it's poor PQ) I don't think the one I tried had a RF mod though.
It was a +R/RW machine only and my notes say besides the PQ I also found the menu system to be annoying/doesn't work well. I think it was quite inexpensive and if I remember correct I bought it from W/M.
Connecting/setup VCR/DVD recorder complicated
By peeaytee in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 15:00 -
Setup Comcast Dig. Cable box to Run through DVD/VCR Recorder
By amish in forum DVD & Blu-ray RecordersReplies: 2Last Post: 1st Dec 2006, 07:47 -
Setup Issues with Panasonic DVD Recorder/VCR combo DMR-ES35V
By keroppikeroppi007 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 28th Nov 2006, 12:37 -
Question regarding Winfast card setup for VCR capture
By jm4747 in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2003, 00:20
