I am relatively new when it comes to subtitles, but I can't seem to demux any of the PGS subtitle streams from the mkv's that MakeMKV creates from blu-ray discs.
I have tried tsMuxerGUI, eac3to, and mkvextract (which I am not sure has PGS subtitle support anyway, but it didn't hurt to try).
tsMuxerGUI simply says...
Some tracks not recognized. These tracks will be ignored.
eac3to says, in this particulary example that I have 3 subtitle tracks...
3: HDMV/PGS, English
4: HDMV/PGS, English
5: HDMV/PGS, English
and then says...
Bitstream parsing for tracks 3-5 failed.
This has happened with every blu-ray video I try to extract subtitles from. I have tried to read around the forum and search google but they all just say use eac3to or tsMuxer to extract the PGS subtitles. Has anyone had success with these subtitles? If so, let me know the process you used in order to extract them.
Thread: Demuxing PGS Subtitles
i am having the exact same problems. Every mkv from makemkv is useless for subs. I have tried almost every program on the net to try en demux the HDMV/PGS sub but no success.
I fanyone knows a way i would really appreciate it if they could explain it here.
It seems i am not the only one.
Thanks,
G
Have you found any easy solution for this? Now I'm using HdBrStreamExtractor (eac3to gui) to extract the subs from the blu-ray instead.
And it would be great with a vsfilter or similar that supports pgs subtitles in mkv.
Can Projectx rip text subtitles from TS without demuxing the other streams?
By Talayero in forum SubtitleReplies: 2Last Post: 31st May 2011, 15:29 -
SupTitle: an AviSynth PGS (.SUP) Subtitle Plugin
By ZachSaw in forum SubtitleReplies: 6Last Post: 11th Feb 2011, 13:03 -
tsMuxer Changes .srt Subtitles to PGS Upon Muxing
By Teutatis in forum SubtitleReplies: 3Last Post: 14th Dec 2009, 01:17 -
Hardcoding PGS into .264 for PS3
By AdamPengelly in forum Video ConversionReplies: 1Last Post: 20th Nov 2008, 16:35 -
Good quality only with all 3 PGS files
By HartsVideo in forum DVD RippingReplies: 11Last Post: 7th Jul 2006, 11:39
Statistics
Newest guides
Latest tool updates
New media comments
