    Hi, I downloaded the newest version of svcd2dvd on my laptop that has vista. I have imgburn and the latest dvdshrink on there also. I don't know which program is giving me the error but once svcd2dvd builds it I have to manually use dvdshrink to shrink it down. Then when I use imgburn to burn it it comes up with an error about the layer break and there is not a spot to put one. I've tried this with single layer and dual layer disks and it does the same thing.
    Anyone else have this problem?
  2. Member ChrissyBoy's Avatar
    Are you putting in chapters?
    I've tried with and without chapters. I've tried doing 2 avi files, 4 and 6 and it comes up with the same error. SVCD2DVD says once it is completed that dvdshrink is starting, but it doesn't. I have to manually go in and shrink it and then use imgburn. I'm assuming that might be a vista thing.I don't understand what is causing this.
  4. Member ChrissyBoy's Avatar
    you say:
    "I've tried this with single layer and dual layer disks and it does the same thing. "
    Does that mean you have a DVD to burn which is 4.37GB or lower and you are using a single layer DVD and yet you still get a error message about Layer breaks from ImgBurn?
  1. Dual Layer problem. Layer break issue...
    By papegoja in forum DVD Ripping
    Last Post: 9th Jun 2010, 23:52
  2. Burning Double Layer DVD with no Layer Break.
    By aspen matthews in forum Authoring (DVD)
    Last Post: 24th Oct 2009, 14:26
  3. Replies: 2
    Last Post: 14th Jun 2007, 13:27
  4. Layer break and DL burning with Nero
    By MrDVD in forum DVD Ripping
    Last Post: 13th Dec 2004, 18:36
  5. Menu, chapter, layer break problem.
    By MaX_NormaL in forum DVD Ripping
    Last Post: 5th Jan 2003, 19:47
About   Advertise   Forum   RSS Feeds   Statistics   Tools
