I'm completely new to the world of video editing and conversion so please bear with me...
I recently purchased the Hauppauge 1212 HD-PVR to capture HD content from my cable box to store on my PC. I'd also like to take some of these HD vids and "downconvert" them to share with others. I figured one way would be to cut the video size, frame rate (60 to 30), and lower the bitrate. I discovered AviDemux and it seems to be capable of doing this.
What I start of doing is cutting the files (.ts) with TsCutter. I use the following settings which were recommended to me: cut-in: I-frame, cut-out: B-frame.
I then import this into AviDemux and change the size and frame rate. From there I encode the file using x264 with average bitrate 2-pass and with an avi container.
This is where I run into a problem. The video looks and operates fine but for some reason in the very beginning (usually within the first 10 frames) the very last frame of the video flashes and fades pixelated just for a split second but it's kind of frustrating. I've been trying to learn about b-frames, i-frames, and p-frames since I believe this has something to do with it.
So I'm not sure where in the process things have gone wrong whether it's the program, encoder, settings, container, etc. Any help would be greatly appreciate as I've been researching for the last few hours trying to figure this out.
try both start and end cuts on I frames which are complete standalone frames. b and p are frames made up from changes in the video. only I frames are suitable for most editors to use as edit points.
how to author a DVD from the beginning to the end
By michcio in forum User guidesReplies: 3Last Post: 13th Apr 2012, 17:43 -
editing video - cutting a few minutes at the beginning and end
By Ally68 in forum Newbie / General discussionsReplies: 6Last Post: 30th Jun 2010, 17:19 -
How do I clean up (trim) beginning and end of DVD?
By perceptionist in forum EditingReplies: 6Last Post: 28th Mar 2010, 00:29 -
Avidemux: The beginning frame is not a key frame. Please move the A marker
By devilcoelhodog in forum EditingReplies: 1Last Post: 10th Jan 2010, 13:56 -
automatically cut out beginning & end of a video
By ari.kulmala in forum EditingReplies: 1Last Post: 25th Aug 2009, 15:44
Statistics
Newest guides
Latest tool updates
New media comments
