ok here is my problem...
i have an xbox 360 premium with HDMI ...it worked with my hanspree 37inch TV without any problems...until i decided to buy a video capture card which was ...blackmagic intensity pro which can can read the encrypted signal of xbox 360 when playing games.
the first time i used blackmagic intensity it worked fine with the computer but then when i decided to output the connection to my tv as well.... it did not work and tried like 5 times without any luck.
so then i decided ok this is a pain ill jus sort this out next time... but i still couldnt
now when i try to connect my hdmi xbox to my tv it jus does not work... i turn it on and a black screen comes for like a second and nothing else..no picture....
but i tested the hdmi and it does work with other HDTVS and also the HDMI on my tv also works with other xboxs hdmi's EXCEPT MY XBOX....
i was told that the tv has something to do with handshake and i had to upgrade my TVs software, i dont think i have that option because the warranty has run out.
is there a way of reseting the whole xbox e.g. the motherboard bios or something
so if there is any way for me to get the hdmi working again it would certainly be appreciated
Results 1 to 1 of 1
Should I get the hdmi/optical cable for my xbox 360 replacement?
By yoda313 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2009, 15:21 -
Best HDMI Splitter for Use with Blackmagic Intensity Pro + Xbox 360?
By xmadmardiganx in forum CapturingReplies: 0Last Post: 22nd Apr 2009, 14:27 -
BlackMagic Intensity + Xbox 360 .. video pass-through using HDMI out??
By norm360 in forum CapturingReplies: 8Last Post: 22nd Apr 2009, 04:48 -
Connecting XBOX 360 with 720p Plasma HDTV: So HDMI or Component Av Cable??
By jajabinks92 in forum DVB / HDTVReplies: 2Last Post: 29th Nov 2008, 08:16 -
I have a question about the new Madcatz xbox 360 hdmi converter
By yoda313 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 20th Jan 2008, 14:52
