After exporting from Final Cut, using Compressor-- i noticed my left audio channel had dropped slightly.
I can't think of any good reason for this?
I watch my levels while editing in FC and everything looks correct--
Anyone ever had a similar experience?
Thanks, guys--
What format are you trying to end up with for your aduio?
ie. AIFF, Ac3, etc?
is the preset your using set for 2 Channel or ?
last, what format was the audio in before hand?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Hi terry--
using compressor, i end up with both an AIFF file (48/16) and an Ac3 file.
the audio beforehand is mostly just the audio straight from the MiniDV tape, as i export directly from FC Pro into compressor.
i'm using a preset in compressor (DVD- Fastest Encode 150 minutes)-- so it doesn't prompt me about 2 channel. it is in stereo, that i can tell--
any more information i can give?
thanks---
just clicked on the preset to view details-- it's a stereo mix
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 6Last Post: 13th Apr 2012, 14:55 -
AC3 File: Audio only on left channel
By koberulz in forum AudioReplies: 10Last Post: 25th May 2011, 12:07 -
DVD missing left channel...
By xichael in forum DVD RippingReplies: 2Last Post: 31st Dec 2008, 16:13 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45 -
My VCR's Left Channel Died
By moviebuff2 in forum Newbie / General discussionsReplies: 17Last Post: 29th Jun 2007, 11:24
Statistics
Newest guides
Latest tool updates
New media comments
