VideoHelp.com Forum
Thread: Eac3to
    thought i would give this a go converting DTS to AC3 how long does the program run until finished its now been 18 hours and still going.
    Something is wrong. Are you using the command line?
  3. Member dragonkeeper's Avatar
    try using e-ac3 and more GUI. be sure to get all the external files. I use it all time process takes less than hour.
    first i set all the preferences.
    then i did the path/sources then on the second tab accross under Eac3to audio i selected the input file and right away it started.
    didnt touch any command line. didnt get a chance.
  1. EAC3TO X to AAC
    By 8xprbhf in forum Audio
    Last Post: 11th Nov 2010, 10:12
  2. eac3to
    By MURPH99 in forum Video Conversion
    Last Post: 27th May 2010, 08:48
  3. EAC3TO error
    By soadtrails in forum Video Conversion
    Last Post: 28th Feb 2010, 18:31
  4. EAC3to keeps me wonder...
    By kulmagen in forum Blu-ray Ripping
    Last Post: 2nd Mar 2008, 14:38
  5. Question with eac3to
    By ultraman36 in forum Audio
    Last Post: 11th Dec 2007, 16:44
