VideoHelp.com Forum
    Good Day,
    I tried ribbot and obtained all the necessary attachments yet it fails to work or create a file.
    I think MAKEMKV worked well but i still ended up with a 27gig mkv file quality superb yet no 5.1 surround or anyform of digital sound.
    The size i think is due to multiple langauges included is there a way to just selct english.
    Any other suggestions of what to use will be welcome thank you.
    The future is written and unwritten every second of the day.
    Did you choose audio track in makemkv?
    But makemkv might not work perfect with all blu-ray, then you can instead try clown_bd.
    Now that you metion it I cannot recall , I was busy with the first one and it was rather very late early morning hours for me before I was set up to run the first try. Thank You for the FEEDBACK
  4. Member dragonkeeper's Avatar
    Would be nice to know which guide you are following then may be I can help a bit. With out knowing what you are doing it's hard to identify the problem.
    What format is the audio in & which software are you trying to play the file in. Some of the freeware stuff is unable to play e-AC3 MPC for one, perhaps with some additional tweaking it can but I have not explored this I down convert e-AC3 to AC3.
    I've been using Ripbot the past few days to convert some of HD content for use on my HTPC and i'm loving it, once i get it set up properly that is .
    1. Use DVDFab HD Decrypter to rip movie.
    2. eac3to And More GUI only to conver movie to MKV & to convert e-ac3 audio to AC3
    3. Use supRead to convert subtitles to srt subtitles.
    4. Use ripbot to convert files to 1080P MKV.
    The conversion process takes a while just under 4 hrs for a two passes. At about 2gig per hour i can't see any perceived quality loss on my 52" TV.
    Dragon Keeper,
    In terms of guides i stick to simple and fast method being new to HD Arena I were trying out a few things it seems you go through a relatively huge process.
    1. Rip anydvdhd "the one solution that works everytime"
    2. MakeMkv one time run after that i got the MKV file to play on my WDHD "Western Digital" player in full 1080p recently did the firmware update as well.
    I realized there are a number people converting to all sorts of formats for play stations and so on.
    So in terms of the 2 step process above I get excellent picture quality. Baldrick pointed out i need to check that i select the correct sound track which i hope will solve the surround problem.
  1. Burning 3d mkv file to blue ray 3d
    By Poetheraven1 in forum Authoring (Blu-ray)
    Last Post: 20th May 2012, 11:59
  2. Blue Ray Player that Plays MKV and MP4 files
    By wulf109 in forum DVD & Blu-ray Players
    Last Post: 27th Dec 2011, 15:56
  3. Reducing the size of a very large .mkv
    By ChienBleu in forum Video Conversion
    Last Post: 20th Mar 2011, 07:19
  4. Blue ray Mkv movies
    By mikethemadmonk in forum Blu-ray Ripping
    Last Post: 19th Jan 2010, 03:22
  5. Is Dolby Digital HD/DTS HD on Blue Ray better than Cinema sound?
    By peggypwr1 in forum Newbie / General discussions
    Last Post: 20th Sep 2008, 23:32
