OK, I'm on Vista Home Premium with all the latest maintenance.
I haven't used SVCD2DVD in quite a while. Tried it, got the splash screen, then nothing. No error messages, no crashes, nothing. SVCD2DVD is no longer in the task list.
So, I downloaded the latest and greatest version, installed it (which, by the way is NOT in Program Files location) and got the same result.
Found a post regarding .NET release (2.x) so downloaded and installed that. (Said it was already on)
Tried running as an Admin. No luck.
Logged on as the Admin and tried. No luck.
So, what now?
Have I just missed a 'magic' post on how to resolve this?
George
Thread: SVCD2DVD used to work, no longer
When you installed the new version, did you get through the registration process?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
I got no prompts for registration, I assumed since I'd registered before that it had just picked up the previous registration data.
Maybe I'll try an uninstall and then a re-install. Its worth a try.
George
OK, completely un-installed and re-installed. This time the Installer proceeded to the registration process. I completed that and all now seems well.
Pretty damn unfriendly though for the App. to simply shut down with no messages whatsoever as to the cause. Sure re-installing fixed it, but then why didn't a 'Repair' install also fix it? Obviously repair doesn't do what it says.
Users should not be left to flounder around without even a clue as to the cause. If the program is smart enough to shut down (not just crash) it should be smart enough to at least issue some message to clue in the user.
The "Repair" option is all down to Windows Installer not the program.
I agree but many programs do this... Windows does this to me several times a week!Pretty damn unfriendly though for the App. to simply shut down with no messages whatsoever as to the cause.
Glad you are back up and running.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
DVD Players no longer work on tv?? Any ideas?
By -mm- in forum DVD & Blu-ray PlayersReplies: 4Last Post: 15th Nov 2008, 20:13 -
svcd2dvd won`t work any more
By NIPPERLOCKO in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2007, 13:27 -
Why will my DVD copies no longer work
By pikkachu in forum Video ConversionReplies: 6Last Post: 29th Nov 2005, 08:21 -
New versions of TMPGEnc and DVD2AVI no longer work together?
By Sam Ontario in forum Authoring (VCD/SVCD)Replies: 17Last Post: 10th Aug 2003, 17:09 -
VFAPI AVI's no longer work..? Help needed!
By bewley in forum DVD RippingReplies: 1Last Post: 10th Oct 2001, 06:13
