I'm Syncing .avi Audio To .MKV Video
I'm using mkvmerge & I don't know what numbers to put in the stretch & delay fields. . .
I have a video file that's 1:45:25.944 & the audio is 1:45:24.359, which is a difference of 1.585
What settings do I put on the audio to make it sync perfectly?
Thanks.
Try the ratio , not difference. If that doesn't work, try the reciprocal
If they are out of sync at the beginning you may need a delay as well
How???Originally Posted by poisondeathray
I don't know how to do this stuff , I need instructions. . .
all I know is I put the audio on successfully, & it is out of sync. . .
but I am totally unfamiliar with this program....
With the video & audio loaded, highlight the audio track, go to the format specific options tab, and enter the ratio in "the stretch by" box, press start muxing
How bad is it out of sync? Judging from the #'s you gave it should be barely perceptible. If it's way off, you have other problems
Is the audio correct? i.e. are you sure it's the correct version?
Does it have errors/dropouts? If so, you won't get it in sync using this method
Does it start in sync? and slowly go out of sync? if it's out of sync at the beginning you probably have to enter a delay as well
it's not that off. . .I'm just nit picky. . .but it's off by half a second throughout. . .& the sounds seem to to fall behind (in sequence) as the video goes on. . .but only by a little. But as the video goes on it becomes slightly more noticeable.
If it's a constant delay scenario, video ahead of audio, you can delay the video by that set amount at the beginning
Similar instructions: highlight video track, format specific options tab, enter delay in ms, press start muxing
But since it seems like you have both (different offset and different lengths), you will have to do a combination of both
I don't know what numbers to put in the delay & stretch fields
I can help you any more with specfics without examining it myself. You can't do this perfectly with only the information you've provided.Originally Posted by ThreatTV
You have to try some values, there will be some testing with trial and error involved here
You said about 1/2 second throughout so try 500ms for the video delay. If it's off, try a bit more or a bit less etc...
Try getting the inital sync first (at the beginning), then the stretch.
Mkvmerge stretch by and delay
By kenryuakuma in forum EditingReplies: 2Last Post: 30th Aug 2011, 13:11 -
Question about using "delay" in mkvmerge.
By Gothic Autumn in forum AudioReplies: 0Last Post: 13th Jun 2011, 21:30 -
MKVmerge / Stretch By / Strategy ?
By stanfield in forum Newbie / General discussionsReplies: 0Last Post: 31st Dec 2010, 11:54 -
MKVmerge - stretch audio
By snadge in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 05:52 -
Foregin subtitles UniCode (SubRip & mkvmerge)
By ronnlund in forum SubtitleReplies: 0Last Post: 9th Sep 2008, 04:19
