VideoHelp.com Forum
  1. Member seven_deuce offsuit's Avatar
    I'm trying to use Vegas 9 Pro (64 bit) to import a M2TS file I ripped from a blu-ray movie. Problem is that it refuses to show the video stream (when highlighted it says "Stream attributes could not be determined"), while the audio stream imports fine. I even tried creating a dummy AVI of it using VFAPI Reader with CoreAVC installed with the same results. I'm guessing it's because CoreAVC isn't 64 bit. I've also tried demuxing the file into VC-1 and AC3 elementary streams, remuxed them in a TS container, then imported it to Vegas which also didn't work either. I haven't even considered converting to a lossless format due to the amount of space it'll take. Any suggestions? Are there any codecs I need? I don't think I can wait for a 64 bit version of CoreAVC to come out.
    All I want to do simply is to be able to edit the M2TS file in Vegas.
  2. Member fitch.j's Avatar
    Could you open it in MediaInfo and post the details here so we can see exactly what your dealing with ?
    CoreAVC doesn't integrate with Vegas. Vegas uses it's own decoder. Also CoreAVC doesn't work with VC-1
    You can use AVS2AVI, (search for it, there is another version but the version you want is the wrapper version that works like VFAPI.) I've used this on a VC-1 blu-ray before for import into Vegas
    of course , lossless intermediate is an option as well
  4. Member seven_deuce offsuit's Avatar
    Here are the Mediainfo details
    CoreAVC + VFAPI method works on my PC with XP 32 bit. Unfortunately even a dummy AVI is too much to handle in Vegas with a Pentium D processor. I think it has something to do with the 64 bit platform I'm using on my laptop with Vista.
    I'm trying to find an alternative to VFAPI and found makeavis that came with ffdshow, but have no idea how to use it. When I try to open it a DOS window opens and then closes.
  1. can't create a blu-ray disc from m2ts
    By hunter2155 in forum Authoring (Blu-ray)
    Last Post: 14th Aug 2011, 06:15
  2. Creating a blu-ray disc from .m2ts and .srt file
    By denada in forum Authoring (Blu-ray)
    Last Post: 26th Aug 2009, 14:29
  3. Forced Subtitles in M2TS - Blu-ray Ripped to HDD
    By saber001 in forum Blu-ray Ripping
    Last Post: 23rd Mar 2009, 06:14
  4. How to edit Sony m2ts files to burn to blu ray disc.
    By tchambers in forum Authoring (Blu-ray)
    Last Post: 11th Nov 2008, 22:53
  5. Working with m2ts files backed up from Blu-Ray disc
    By Lovepeaceguru in forum DVD Ripping
    Last Post: 15th Dec 2007, 06:55
