I have an HP DH-6AYH113C p/n 5188-7536 super multi DVD burner, made by Samsung I think. It has
burned about 600-700 DVDs. It is now burning almost as many coasters as
good disks (I always use either Nero or ImgBurn and verify). In the past it did not seem to be media sensitive as most all
brands I have tried worked with very few failures.
Is this thing at the end of its useful burning life?
Advice/help appreciated, John.
Thread: DVD Burner life
Have you updated the firmware to the latest version?
Might need to clean the laser or replace the burner,they are worth only $25-30 now adays.
Ben Johnson-I didnt take any stereos!
If you're using crappy ass MEMOREX or TDK dvd discs that could be the problem. If not then buy a new dvdrw since they're so cheap these days as already stated.
Read in here, too:
http://www.digitalfaq.com/forum/foru...-media-19.html
Especially the post about cleaning DVD drives properly.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Thanks for the replies and links, quite helpful. I bought a new LG SATA Super Multi DVD Rewriter GH22 for CA$37.00, problem solved.
John.
Good decision. When burners start to go bad they are cheap enough that I don't think it's worth trying to salvage them. Replacement seems to be a good course of action. Although it is unusual, I've seen burners fail as early as after just 2 or 3 months of non-heavy usage. Computer components can fail at almost any time, unfortunately.Originally Posted by hibbs
Cleaning is the best first choice. If that does not work, then scrap it, yes.
Burning at lower speeds lengthens the life or your burner?
By LittleQueenie in forum MediaReplies: 10Last Post: 25th Jun 2007, 19:40 -
Get a Life! a 2nd Life in this outta-the-box Virtual Reality community
By ahhaa in forum ComputerReplies: 0Last Post: 1st Sep 2006, 11:18 -
what's the life span of a DVD RW?
By archaeo in forum MediaReplies: 7Last Post: 3rd Jan 2005, 19:31 -
Life of DVD-R ?
By arminio in forum DVD & Blu-ray RecordersReplies: 26Last Post: 26th Aug 2003, 03:57 -
THE LIFE AND OF A BURNER!!
By F-ING HOSTILE in forum DVD & Blu-ray WritersReplies: 17Last Post: 19th May 2003, 01:57
