Hi, I'm just having here a 16:9 NTSC DVD video source.
My goal is to restore the orginal video format.
Is there a way to change the PAR or SAR values without re-encoding the whole video?
If you just want to adjust AR (e.g. if it wasn't set properly in the first place), you can try restream or dvd patcher. But any restoration efforts will require re-encoding
Ahhh, restream seems to be good enough for this purpose.
Would be quite desirable to have a programm that could demultiplex and change it to 1:1 in one step^^
DVD video is never "1:1". None of the available pixel aspect ratios give square pixels.
Cheers,
David.
Ok so then wht do I do when I change it to square pixels...I know the DVD doesn't have that setting...but what you are saying is just a little confusing to me o.o
You resize and reencode. DVDs are only 4:3 or 16:9, never 1:1.Originally Posted by Weef
I want to transform my PSF MTS camcorder video without reencoding the video
By Stears555 in forum Camcorders (DV/HDV/AVCHD)Replies: 20Last Post: 8th Feb 2012, 05:52 -
Is it recommended to convert or it leave it at their original flv format?
By leandro in forum Newbie / General discussionsReplies: 9Last Post: 6th Dec 2011, 11:59 -
How can i creade a Dvd video from camera files w/o reencoding them?
By junglemike in forum Authoring (DVD)Replies: 6Last Post: 7th Apr 2009, 19:41 -
Converting from VOB to any other format - doesn't keep the original size
By Mylo in forum DVD RippingReplies: 5Last Post: 14th Mar 2009, 13:58 -
How to backup multiple AVCHD files to BD-format DVDr without reencoding
By jodal in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Dec 2008, 15:45
