VideoHelp.com Forum
    I have a movie (Requiem for a Dream) on my hard drive (used AnyDVD HD), and I'm attempting to use TSmuxer to produce a .m2ts file with the movie's audio track. I've attached a screenshot of what I've tried, which resulted in video, but no sound. (also, I did actually remove the other tracks when I tried it, I just left them in for the screenshot).
    I'm not sure if this is in any way relevant, but when I play the main movie file using PowerDVD, it does not play with the proper sound track. Instead, it plays with the director's commentary.
    Any help would be much appreciated. Thanks
    Just because you don't hear audio doesn't mean there isn't an audio track in the stream, load you finished stream back into TsMuxeR and it will show you
    I don't know your setup, but you may need to downconvert (check the "down convert" box" that HD audio you have selected
    ocgw
    peace
    Athlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
    http://forum.videohelp.com/topic368691.html
    Well, I was able to determine that I needed to extract the .dts audio, then convert it to AC3 (using EAC3). My problem now, however, is that the audio is extremely quiet-- I have to turn my sound system all the way up to hear anything at all.
    duplicate post
    I'm sorry? Should I start a new thread on the issue of the inaudible audio?
    PDVD plays DTS, why convert it to AC3 w/ eac3t?
    ocgw
    peace
    Well, I burned a disc using the DTS track and when I play it in PowerDVD I have no audio.
    Did you down convert to standard DTS 5.1?
    What is your speaker setup? optical, coaxial, or analog?
    ocgw
    peace
  1. Recovering quiet audio
    By ReedJohansson in forum Audio
    Last Post: 20th Mar 2012, 05:03
  2. Replies: 6
    Last Post: 1st Jan 2011, 08:28
  3. TsMuxeR AC3 audio track with Narrator problem
    By Tony Nguyen in forum Authoring (Blu-ray)
    Last Post: 11th Dec 2010, 10:27
  4. Audio is extremely low
    By Nintendo Fan in forum Audio
    Last Post: 26th Aug 2010, 15:43
  5. Converted mkv has extremely slow audio
    By PandaShake in forum Video Conversion
    Last Post: 4th Jul 2009, 03:15
