Hi all,
Just downloaded and used the latest 3.00 (free) version and as the review comments indicated works very well.
Question - I am merging "ripped" TS_VIDEO VOBs into a single MPEG and am curious what level of MPEG the program creates. (i.e MPEG, MPEG2, MPEG3, MPEG4).
My goal is to convert all my "ripped" VOBs so as to stream them to a PS3 via a server running Windows Home Server O/S.
Many Thanks
In IFO Mode mpegs are created per Title. (In PRO you can also split per chapter...)
In VOBSET mode mpegs are created per TitleSet.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Many thanks for the quick reply.
Are the VOBs converted to MPEG 2 or ???
Rather than "converted", mpeg2 is extracted from the vobs.
Thank you,
Should be perfect for my home storage / streaming project.
Hopefully after gaining some experience with the program and all the video concepts I will be looking forward to the upgraded version capabilities.
Need suggestions from pros on how to process low-level audio
By Asterra in forum AudioReplies: 2Last Post: 1st Jul 2011, 19:57 -
Seeking elegant h.264 -> Mpeg2/DVD conversion process
By bigass in forum Video ConversionReplies: 5Last Post: 21st Aug 2010, 20:42 -
AVC level 5.1 to AVC level 4.1 conversion?
By tomisoft in forum Video ConversionReplies: 3Last Post: 26th Dec 2009, 20:18 -
ffmpeg and mpeg-4 visual simple profile level 3 (packed bitstream)
By Witchking in forum LinuxReplies: 2Last Post: 6th Oct 2009, 13:08 -
how to keep the HD in my conversion process?
By masadar in forum Newbie / General discussionsReplies: 9Last Post: 21st Dec 2008, 12:41
