    Hello guys.
    I've figured out most of what I need to with ffmpegX, but I'm confused about subtitles. I can get them to burn, but I can't get them to burn with the font settings I choose. If I set the settings to a different font and change the position, and then burn, the file that's output has the subtitles positioned differently, but still in skinny, difficult-to-read Arial font, no matter what font I choose. Am I doing something wrong? Does anyone have suggestions as to what I should try? The preview always looks all right, but the finished product never reflects the preview...
  2. Explorer Case's Avatar
    There is a known bug in the version of mencoder that ffmpegX uses, it does not respect some of the subtitle settings (font and text encoding), while an older version of mencoder didn't show this behavior. The preview is rendered by mplayer, which does not have this bug.
    It is possible to substitute current mencoder for an older one, but if you do then you should be aware that some of the newer functions (H.264?) will not work, as they were not implemented in the older mencoder.
    If you install an older mencoder version, then ffmpegX will notice and warn you each launch, but it will work with it anyway.
    This older version of mencoder is from the 2005-01-23 package that came with ffmpegX 0.0.9s.
    http://forum.videohelp.com/topic357488.html
    http://forum.videohelp.com/topic319466.html
    http://forum.videohelp.com/topic316142.html
    Thank you so much. I'll try this out and see if I can get it all working!
  1. Fonts
    By bryankendall in forum Computer
    Last Post: 1st Sep 2008, 23:05
  2. Fonts Like You've Never Seen Before
    By Soopafresh in forum Computer
    Last Post: 26th Jan 2007, 04:14
  3. What are those fonts?
    By Neisse in forum Authoring (DVD)
    Last Post: 7th Mar 2006, 03:05
  4. Adding fonts for use with tmpg dvd author + subtitle problem
    By trooper11 in forum Authoring (DVD)
    Last Post: 17th Mar 2005, 18:48
  5. Problems with subtitle fonts
    By javi6543 in forum Editing
    Last Post: 18th Nov 2003, 13:28
About   Advertise   Forum   RSS Feeds   Statistics   Tools
