VideoHelp.com Forum
    Hi everyone,
    Here's my problem: i want to burn an .Mkv file containing a blu ray on a dvd and read it on a pioneer bdp 320 standalone player.
    I ve tried converting the mkv with tsmuxer (blu ray and avchd) and then i burnt the result on a dvd in udf 2.50 mode (finalized).
    Whatever i do (i tried nero, img burn, blu ray and avchd), my player simply won't recognize it.
    Can anyone help me? Am i doing something wrong or is it my player that has a problem ?
    thx
    According to http://forum.doom9.org/showthread.php?t=146339 it should support AVCHD.
    Have you also tried different dvd media?
    Is the mkv source avhcd/blu-ray compliant? you may have to reconvert it using uncropmkv.
    And try also multiAVCHD.
    thx for your answer
    i only tried dvd +rw (that's alla i have right now).
    As for the mkv, i dunno how to answer your question : all i can say is that it contains a .264 1920:800p video 23.976 fr and a 5.1 channels 48khz audio 1536 Kbps.
    whats multiavchd ? tsmuxer doesnt support it if i am not mistaken
    all right, sorry im a noob, multiavchd and uncropmkv both tell me its not compliant (height)...
    so i suppose i have to resize (or uncrop ?) to 1920:1080 ??
    only pb is the image looks real weird that way...
    anyway i'll try, thx for the piece of advice
  5. You already posted @my forum, but a short note here, too: uncropping won't stretch the image but will add the black borders so it fills the full 1080p frame - it shouldn't look weird. I suggested that you first find a small compliant clip and try all the options to check what your player supports.
    Laugh and the world will laugh with you. Cry and you will be alone
  1. issues playing burned DVD's on sony blu ray player bdp-s300
    By cdcutlip in forum DVD & Blu-ray Players
    Last Post: 7th May 2011, 15:12
  2. Anyone going to buy the new Oppo BDP-83 Blu-ray player?
    By edDV in forum DVD & Blu-ray Players
    Last Post: 2nd Oct 2009, 04:59
  3. Blu Ray Sony BDP-S350
    By dreyko in forum DVD & Blu-ray Players
    Last Post: 7th Oct 2008, 14:24
  4. My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
    By showgirl in forum Newbie / General discussions
    Last Post: 2nd Oct 2007, 12:48
