Hi, I was looking to purchase an LG Blu-ray player which supports MKV file playback. Can I just burn the MKV files to dvd for playback on this player or do the files have to run through the usb media connection. Their website isn't specific
as to what will play directly off of disc. Any help would be appreciated.
The only other thing I could think of was using TxMuxer to create a AVCHD dvd. If so will there be quality loss?
1. Read/Search in http://www.avsforum.com/avs-vb/showthread.php?t=1124111
. But I have only seen reports about mkv through the usb connection.
2. Well if you have to SHRINK it to one DVD you will be losing quality.
I have no personal experience with this player, but based on past experience with DVD and Blu Ray players you should be aware that typically standalone players don't support everything. If the resolution of your MKV file is not 1280x720 or 1920x1080 or 720x480 it may not play. Some video encoding options are probably not supported and quite possibly some audio options won't be supported either. Generally speaking media players such as the Western Digital HDTV and similar players are much less fussy about what they will play.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 51Last Post: 1st Dec 2011, 06:10 -
Playback of h264 files does not have the subtitles-New Blu-Ray player
By LuckyLyndy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Dec 2009, 01:23 -
Watching my MKV files via USB on my blu ray player
By JulesWinnfield in forum Newbie / General discussionsReplies: 7Last Post: 19th Oct 2009, 18:15 -
Best way to convert/burn/play .mkv H.264 Blu-ray/HD DVD files on a Mac
By iMacMan in forum MacReplies: 7Last Post: 21st Mar 2009, 17:50 -
Blu ray m2ts files not in order? mkv conversion
By davidc78au in forum DVD RippingReplies: 3Last Post: 11th Feb 2008, 12:39
Statistics
Newest guides
Latest tool updates
New media comments
