    I am using TsMuxer to take several .mts files and combine then into 1 file. I then use AVStoDVD to burn my .ts video. After I burn my DVD and play it back on my home DVD player, I'm noticing that the everything is probably 10-20% slower than real life. If I view the original video from my camcorder, it looks fine. What's typically the issue when play back is a little slow? What information can I provide you all that might help in the determination of my slowness.
    thanks again and always for your help.
    joe...
    What is source mts framerate? Use Mediainfo if you are aren't sure.
    And to what framerate are you converting?
    If you play the dvd on your computer does it also play slow?
  3. AVStoDVD Author _MrC_'s Avatar
    @godwentpunk
    post the AVStoDVD log file, it could help a lot.
    Bye
    MrC
    AVStoDVD Homepage
    Yes, DVD played on PC is slow was well well. In fact, when I view the VOB files from my PC, they are slow too. So I'm guessing that it's something within my decoding process.
    Here is my log file:
    <9/18/2009 12:46:39 AM>
    START PROCESS
    <9/18/2009 12:46:40 AM>
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 1
    DVD Size: 2863/4435 MB (65%)
    DVD Output Setup: Burn DVD
    DVD Label: DVD
    DVD Menu: Static Menu
    DVD Burning Drive: E: SONY DVD RW DRU-842A 1.60
    DVD Burning Speed: 4x
    Output Folder: H:\TEMP DVD
    Save Log file: Yes
    Delete Temp Process Files: Yes
    Delete Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    TITLE 1 SOURCE FILES
    Video: H:\Camcorder Videos\09-3-2009\DriaVolleyBall_09_01_2009.ts
    Info: AVC - 10604 kbps - 1920x1080 - DAR 1.778 - 29.97 fps - Interlaced (TFF) - 42:43 minutes - 76825 frames
    Audio: H:\Camcorder Videos\09-3-2009\DriaVolleyBall_09_01_2009.ts
    Info: AC3 - 256 kbps - CBR - 48000Hz - 2ch - 42:43 minutes
    Subs:
    [MediaInfoLib - v0.7.19]
    AVISYNTH SCRIPT
    Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("H:\Camcorder Videos\09-3-2009\DriaVolleyBall_09_01_2009.ts", CacheFolder = "D:\CamcorderMov\temp")
    Video = Video.ConvertToYV12(interlaced = true)
    Video = Video.ChangeFPS(29.97,false)
    Video = Video.Lanczos4Resize(720,480)
    Return Video
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: HCenc VBR 2-pass
    Target Video FileSize: 2749.8 MB
    HCenc Parameters: -ini "D:\CamcorderMov\temp\DVD_5_DriaVolleyBall_09_01_2 009.HCenc.ini"
    HCenc ini file:
    *INFILE D:\CamcorderMov\temp\DVD_5_DriaVolleyBall_09_01_20 09.avs
    *AVSRELOAD
    *OUTFILE H:\TEMP DVD\DVD_5_DriaVolleyBall_09_01_2009.m2v
    *LOGFILE D:\CamcorderMov\temp\DVD_5_DriaVolleyBall_09_01_20 09.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 9000
    *PROFILE BEST
    *ASPECT 4:3
    *INTERLACED
    *TFF
    *BIAS 90
    *DC_PREC 10
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 0
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <9/18/2009 6:27:28 AM>
    END VIDEO ENCODING OPERATIONS
    A2DVideoSource: DirectShowSource
    Created File: H:\TEMP DVD\DVD_5_DriaVolleyBall_09_01_2009.m2v (2421.7 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 8068 kbps - 720x480 - DAR 1.333 - 29.97 fps - Interlaced (TFF) - 42:41 minutes - 76753 frames
    START AUDIO DEMUXING OPERATIONS
    FFmpeg Parameters: -i "H:\Camcorder Videos\09-3-2009\DriaVolleyBall_09_01_2009.ts" -acodec copy "H:\TEMP DVD\DVD_5_DriaVolleyBall_09_01_2009.ToFix.ac3"
    <9/18/2009 6:30:51 AM>
    END AUDIO ENCODING OPERATIONS
    Created File: H:\TEMP DVD\DVD_5_DriaVolleyBall_09_01_2009.ac3 (78.2 MB)
    OUTPUT AUDIO INFO: AC3 - 256 kbps - CBR - 48000Hz - 2ch - 42:43 minutes
    <9/18/2009 6:30:52 AM>
    START DVD MENU BUILDING OPERATIONS
    DVD Menu settings: Style 0, DAR 0, Titles Format 1, Video BitRate 6000, Menu Pages 1, Menu Titles 1
    <9/18/2009 6:31:15 AM>
    END DVD MENU BUILDING OPERATIONS
    Created File (Menu Page 1): D:\CamcorderMov\temp\DVD_5_MenuPage1.bmp (1 MB)
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "D:\CamcorderMov\temp\DVD_5_BatchMux.ini"
    BatchMux ini file:
    -d "H:\TEMP DVD\DVD_5\VIDEO_TS"
    -mxp "D:\CamcorderMov\temp\DVD_5_MuxMan.mxp"
    -l "D:\CamcorderMov\temp\DVD_5_MuxMan.log"
    -muxman "C:\Program Files\AVStoDVD\MuxMan"
    -prio LOW
    -v "H:\TEMP DVD\DVD_5_DriaVolleyBall_09_01_2009.m2v"
    -vidmode 4:3
    -a1 "H:\TEMP DVD\DVD_5_DriaVolleyBall_09_01_2009.ac3"
    -a1lang en
    -cellfr "D:\CamcorderMov\temp\DVD_5_DriaVolleyBall_09_01_2 009_MuxMan.txt"
    -progfr "D:\CamcorderMov\temp\DVD_5_DriaVolleyBall_09_01_2 009_MuxMan.txt"
    -chapfr "D:\CamcorderMov\temp\DVD_5_DriaVolleyBall_09_01_2 009_MuxMan.txt"
    -SEG2v "D:\CamcorderMov\temp\DVD_5_MenuPage1.bmp"
    -SEG2vidmode 4:3
    -SEG2s1 "D:\CamcorderMov\temp\DVD_5_Menu.sst"
    -SEG2s1dmode LB
    -SEG2hlmnu "D:\CamcorderMov\temp\DVD_5_MenuPage1_Buttons. mnu"
    -SEG2hlcsm "C:\Program Files\AVStoDVD\Menu\Highlight_Scheme.csm"
    -hcn "D:\CamcorderMov\temp\DVD_5_BatchMux.hcn"
    <9/18/2009 6:36:06 AM>
    END DVD AUTHORING OPERATIONS
    Created Folder: H:\TEMP DVD\DVD_5 (2544 MB)
    <9/18/2009 6:36:07 AM>
    START DVD BURNING OPERATIONS
    ImgBurn (DVD) Parameters: /mode isobuild /buildmode device /src "H:\TEMP DVD\DVD_5\VIDEO_TS" /dest E: /volumelabel "DVD" /speed 4x /erase /testmode no /verify no /noimagedetails /start /waitformedia /close
    <9/18/2009 6:45:15 AM>
    END DVD BURNING OPERATIONS
    Created DVD: <DVD> in drive E: SONY DVD RW DRU-842A 1.60
    Using MediaInfo, here is the stat's on my VOB files:
    General
    Complete name : H:\TEMP DVD\DVD_5\VIDEO_TS\VTS_01_1.VOB
    Format : MPEG-PS
    File size : 1 024 MiB
    Duration : 17mn 13s
    Overall bit rate : 8 312 Kbps
    Writing library : |HCenc 0.23.0.0 - (c) 2004/2008|
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, Matrix : Default
    Duration : 17mn 13s
    Bit rate mode : Variable
    Bit rate : 7 726 Kbps
    Nominal bit rate : 9 000 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 fps
    Standard : NTSC
    Colorimetry : 4:2:0
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.746
    Stream size : 952 MiB (93%)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 17mn 13s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Stream size : 31.5 MiB (3%)
    Anyone got any ideas why I'm experiencing slow playback? I want to burn some more stuff and would like to have things at the proper speed.
    thanks!
    joe...
    Just checking in to see if anyone has any further suggestions. Did the log files help?
    joe...
  1. dvd's I burned do not always play on television
    By geminidreamer in forum Newbie / General discussions
    Last Post: 14th Nov 2009, 19:29
  2. why can't I play my burned dvd's on my Magnavox mwr10d6
    By totalyscrewedup in forum Authoring (DVD)
    Last Post: 6th Oct 2009, 12:35
  3. Slow Motion Play Back
    By richardholt in forum Newbie / General discussions
    Last Post: 28th Jan 2007, 02:06
  4. PS2 Won't play burned DVD's
    By c-piddy in forum Newbie / General discussions
    Last Post: 5th Jan 2004, 03:04
  5. Replies: 9
    Last Post: 25th May 2003, 14:02
About   Advertise   Forum   RSS Feeds   Statistics   Tools
