VideoHelp.com Forum
    I've got a few recordings on my Sky HD box that were from normal channels. The Sky box can upscale them to 720p or 1080i, bt as the broadcast was in 576i it seems pointless capturing at a HD level when my Popcorn can play them at 576i and do teh upscaling.
    Would there be any point in capturing with it upscaled to 720p, or should I just stick to 576i?
    Cheers guys
    You should try it yourself but the upscaled video is not likely to look any better (it will depend partly on which device has the better upscaler) and will require more bitrate.
  3. Member yoda313's Avatar
    One thing to consider was whether or not these "normal channels" contained surround sound. If they did than it would be worth using the hd pvr to preserve the digital surround sound.
    However I am unaware of any cable/sat/fios service that broadcasts 5.1 surround sound on standard definition channels. It would be nice if they did but I don't think they do.
    If it is regular stereo than you would probably be best to capture it in one of two ways - turn off the upscaling feature on your hd box - or capture via composite with a normal standard def capture device. That way if its sd to begin with capturing to sd will save you post processing time. Unless your destination is something like a popcorn hour or wdtv media player that can handle different formats.
  1. Hauppauge 1212 HD PVR & VirtualDub
    By MakiManPR in forum Capturing
    Last Post: 23rd Oct 2011, 11:31
  2. Hauppauge 1212 HD-PVR
    By tomfranklin in forum Linux
    Last Post: 28th Sep 2010, 10:33
  3. Xbox 360 - Hauppauge HD PVR 1212 - Please Help
    By twblindv2 in forum Capturing
    Last Post: 14th Apr 2010, 16:29
  4. hauppauge hd pvr 1212 Capture Issues
    By jwack in forum Capturing
    Last Post: 19th Nov 2009, 20:17
  5. hauppauge HD PVR 1212 workflow
    By unplug in forum Editing
    Last Post: 5th Sep 2008, 15:21
