VideoHelp.com Forum
    I want to run external mics into my Sony DCR-TRV-20 video camera. I'm using condenser mics, running them through a Tascam Digital Portastudio digital recorder for phantom power. I don't want to blow out any circuits in the camera because of mis-matched impedance. Here are the specs: camera: minijack, 0.388 mV low impedance with 2.5 to 3.0 V DC, output impedance 6.8 kilohms. Digital recorder output impedance: 1K (omega symbol). Nominal output level: -10dBV, maximum output level: +6dB. Will this work OK? thank you... Larry Larson
    Anybody out there know the answer to this, or where I could go to get some information? thanks....
  3. Member edDV's Avatar
    http://www.kiva.org/about
    OK thank you very much. What would happen if I didn't use a transformer? Would I blow out the camera audio circuit, or would I just have less than optimal sound quality?
  5. Member edDV's Avatar
    You wouldn't hear it. The transformer boosts level and matches impedance.
    The Shure A96F transformer connects microphones with an XLR-type connector to the 3.5 mm inputs found on camcorders and other recording devices. It increases the signal level from the microphone, provides a balanced input, and prevents distortion due to the DC bias voltage typically found in camcorder microphone inputs.
    Balanced input 600 ohm would allow very long mic cable runs.
  1. External mic
    By ipaddle4fun in forum Newbie / General discussions
    Last Post: 7th Mar 2011, 21:46
  2. Replies: 1
    Last Post: 24th Apr 2010, 18:38
  3. Transferring video from Sony DCR TRV 285E to PC ...need dv sample
    By ganduman in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 12th Mar 2009, 09:20
  4. Recording video from external source? (Sony DCR-HC96 and others)
    By kb1985 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 13th Jan 2008, 17:46
  5. Sony DCR HC 90E Handycam: How to Attach a Remote External Microphone?
    By gasp4air in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 28th Nov 2007, 09:05
