Hi
I have a Panasonic DMR EZ27 Dual DVD-VHS Box and am trying to convert some old educational tapes to DVD. Some work fine with tape over the back but a few just fail on copy protection. I have read about signal boosters. Is there any way around this problem using the Panasonic box or will I have to do it through the PC?
Cheers.
From my understanding, such a signal/decoder/stabilizer type of tool is meant to be situated "in between" the VHS playback and the capturing device.
For a stand-alone VCR to a capturing device this is straightforward since the wires/cables are external and can be easily mediated with the tool.
On a combo machine, it seems theoretically possible, but in practice seems only possible if you gut the machine to install this tool and you may have to know something about electronics to do so to capture copy-protected tapes.
But before shopping for other capturing equipment, or fetching that soldering iron you just so happen to have conveniently around, are you able to hook a separate, stand-alone, VCR into your combo and record this way without needing the internal VCR unit? If so, then you can use such a decrypting tool very easily.Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
connecting a PVR and DVD/VHS unit to a TV
By affa44 in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2008, 01:45 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
VHS to DVD all in one unit
By robroth in forum DVD & Blu-ray RecordersReplies: 15Last Post: 4th Nov 2008, 21:04 -
Wanted: inexpensive DVD Recorder/VHS Combo unit that is reliable
By Kmical in forum DVD & Blu-ray RecordersReplies: 4Last Post: 20th Feb 2008, 10:57 -
ATSC Tuner Question with DVD Player/Recorder/VHS Combo Unit
By Surfmaster in forum DVB / HDTVReplies: 4Last Post: 17th Dec 2007, 20:01
Statistics
Newest guides
Latest tool updates
New media comments
