VideoHelp.com Forum
  1. I've noticed in the various calculators and encoder apps that I've tried, that altering the resolution field does not cause any change in the projected file size.
    I always thought that lower resolution means less data, and therefore smaller size, but these calculators don't show it. Is this because they can't project it very well? Is there some way for me to get a ballpark idea?
    It doesn't , at least not directly
    Filesize = bitrate x running time
    But a larger resolution will require more bitrate for it to keep the same level of "quality", and more complex material (e.g. action scenes, lots of movement etc...) will also
    It's just the video and audio BITRATE and runtime that affects the file size when you calculate the file size.
    1000kbit/s 1920x1080 and 1000kbit/s 320x240 = same file size.
    But of course will the 1920x1080 look like crap.
  4. Ok, that clears it up. Thanks.
  1. Correct size Resolution for AVI
    By Sliztzan in forum Editing
    Last Post: 25th May 2010, 10:01
  2. Question: MKV File Size vs MP4 File Size
    By VideoNoobz in forum Mac
    Last Post: 20th Feb 2010, 02:44
  3. Does a files resolution affect conversion speed?
    By perdomot in forum Video Conversion
    Last Post: 5th Nov 2009, 06:22
  4. Converting resolution size
    By Illusionist in forum Newbie / General discussions
    Last Post: 11th Mar 2008, 01:38
  5. How does GOP size affect recording ?
    By Serville in forum Capturing
    Last Post: 17th Dec 2007, 08:02
