I have a small issue and was wondering if any of you guys know more about how CPU intensive certain codecs are.
I've got to play some video's on a projector screen that is connected to a very old PC. (1.8ghz single core)
The client usually asks for the video in MPEG2 format, at 1280x720:
Filesize is not really an issue, however too large and evidently this will take more work by the CPU.Format : MPEG-PS
File size : 332 MiB
Duration : 3mn 41s
Overall bit rate : 12.6 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High-1440
Format settings, Matrix : Default
Duration : 3mn 41s
Bit rate mode : Variable
Bit rate : 11.7 Mbps
Nominal bit rate : 12.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate : 25.000 fps
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.507
Stream size : 309 MiB (93%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 3mn 41s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Video delay : -80ms
Stream size : 10.2 MiB (3%)
I'm willing to take some quality loss as obviously there is no way to avoid this, however with it being projected, i'd like to keep it as reasonable as possible.
I'm not sure if any other formats will work any better ? I'm aware of certain formats that are more CPU intensive (H264 for example) but not of which ones are lighter on the CPU.
I may just have to reduce the bitrate of the MPEG2 if there are no better options.
Cheers for any help.
Try mpeg1. Convert using the old free tmpgenc 2.5.
However mpeg-1 might struggle with quality at those resolutions unless you use a high bitrate, in which case you are probably better off with mpeg-2.
I would question the need for that resolution. You will get better quality blowing up SD res video that has been well encoded with a reasonable bitrate, than having HD res video encoded at a poor bitrate.
I didn't realise MPEG1 would be any better than MPEG2 so i'll give that a go cheers!
I'll just re-encode it from Media Encoder as then its using the source footage ( 1080i )so best chance at keeping quality at lower bitrates rather than re-encoding an already compressed encode.
I'll render out a few tests at SD resolution to compare.
MPEG is looking to be the best option then still ? I was considering trying WMV to see how that worked.
Best Video Format/Codec For Small Size, Yet Low Loss In Quality?
By kiwisoup in forum Video ConversionReplies: 13Last Post: 27th Jul 2010, 10:01 -
Low CPU Real time Video Encoding
By striker9 in forum Video ConversionReplies: 4Last Post: 27th May 2010, 10:54 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Best Video codec for ultra-low bitrates?
By theaveng in forum Newbie / General discussionsReplies: 30Last Post: 31st Jul 2008, 10:41 -
looking for low cpu usage video player.
By eroy in forum Software PlayingReplies: 4Last Post: 20th Feb 2008, 10:34
Statistics
Newest guides
Latest tool updates
New media comments
