VideoHelp.com Forum
    Hello all,
    I have a ripped movie in HD-DVD format that a friend gave me, I would like to convert it into MKV abnd i have problems with the sound.
    I can convert it into mkv using super and stream settings all around (audio and video) but it loses the DTS audio track and I'd like to keep this one since it should be better than the AC3, how can I do this ?
    Here are the file details
    Vidéo
    ID de menu : 1 (0x1)
    Format : MPEG Video
    Version du format : Version 2
    Profil du format : Main@High
    Paramètres du format, Matrice : Par défaut
    Durée : 29mn 17s
    Type de débit : Variable
    Débit nominal : 40,0 Mb/s
    Largeur : 1 920 pixels
    Hauteur : 1 080 pixels
    Format à l'écran : 16/9
    Images par seconde : 23,976 Im/s
    Colorimétrie : 4:2:0
    Type d'image : Progressif
    Bits/(Pixel*Image) : 0.805
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Profil du format : MA
    Durée : 29mn 17s
    Canaux : 6 canaux
    Position des cannaux : Front: L C R, Surround: L R, LFE
    Echantillonnage : 48,0 KHz
    Résolution : 24 bits
    Langue : Anglais
    Audio #2
    Format : AC-3
    Format/Info : Audio Coding 3
    Durée : 29mn 16s
    Type de débit : Constant
    Débit : 448 Kbps
    Canaux : 6 canaux
    Taille du flux : 93,8 Mio (2%)
    Langue : Anglais
    You can use tsmuxer to rip out the dts from the ts and then add it to the mkv using using mkvtoolnix.
    And I would use Ripbot264 to convert the ts to mkv h264. It can also keep the dts and ac3 audio.
  1. Problem conserving 5.1 from MKV conversion
    By l'ensemble in forum Mac
    Last Post: 24th Jan 2011, 14:35
  2. MKV Conversion Problem - Video 4 Minutes Too Short!
    By Nodoka in forum Video Conversion
    Last Post: 15th Sep 2010, 10:39
  3. Problem on MKV Conversion. Please help.
    By maicans in forum Video Conversion
    Last Post: 11th Jun 2010, 11:17
  4. Problem with mkv to DVD conversion
    By LoafingOaf in forum ffmpegX general discussion
    Last Post: 27th Oct 2009, 06:46
  5. aimersoft mkv conversion problem...
    By freewheelin in forum Video Conversion
    Last Post: 6th Sep 2009, 13:22
