I have tried to back up Close Encounters but there are over 130 M2TS files and none of them contain the whole movie. I have tried piecing them together but there are 3 different versions on the disk and I don't know the film too well. Also it is very episodic anyway. Is there anything that can guide me through this maze?
Results 1 to 11 of 11
carpe diem maņana
BD Rebuilder?
Or do you want to backup to ts,mkv,mp4, etc?
This type of release does not lend itself to "fly by wire" simple backup by picking and choosing files off the disc: don't even try. The only sensible method is via freeware, shareware or paid backup packages that will just take the whole damn disc and compress it to a DVD-5 or uncompressed dual-layer DVD-9 (given the visual FX are the only reason for this films existence, you probably want a DL uncompressed backup). Try the DVDFab products recommended by most VH members, or the much more elaborate DVDrebuilder if you really want to tinker. I use SlySofts CloneDVD/AnyDVD duo, works for me every time. You'll definitely need both a decrypter and a "shrinking" or backup application. In my case, AnyDVD decrypts in the background while CloneDVD makes the actual backup. CloneDVD has a preview window that lets you look at all the various bits and pieces on the DVD, each of which has a check box allowing you to seamlessly delete them from the backup DVD (handy to get rid of logos, commercials, trailers, bonus extras you don't want that eat up disc capacity). Presumably other backup packages have similar functions. Because of the unusual "three branching versions on one disc" formatting of Close Encounters, you should perhaps just back up the entire disc: editing out the junk may be tedious to do and/or cause playback problems.
Those kind of blu rays are called "seamless branching discs"Originally Posted by fazza8
http://en.wikipedia.org/wiki/Seamless_branching
All you need to do is download the latest version of TsMuxeR, and load the correct "main movie" .mlps file in the same window you would pick the .m2ts file
You can determine the correct .mpls file w/......
BD Edit
BD info
Eac3to (you have to download GUI seperately)
I like Eac3to, so far it has never been wrong
note: W/ TsMuxeR you can remove the audio streams and subtitles you don't need to get 80-90% of the movies small enough to fit on a SL BD disc w/o compression
ps. To orsetto: He is talking about blu ray, not DVD, there is no such thing as a uncompressed blu ray backup to DVD-9, which is more accurately refered to as "BD-9"
ocgw
peaceAthlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
http://forum.videohelp.com/topic368691.html
Yes, I realized that this morning (answering posts late at night when bleary-eyed can lead to errorsOriginally Posted by ocgw
) Since fazza8 didn't specify BluRay, I mistakenly assumed he meant standard DVD. I momentarily forgot only the Blu Ray release has the three versions on one disc, the standard release has them on three individual discs. I'm gonna let my post stand, though, since casual users may still want to investigate the dedicated backup packages. Clone DVD/AnyDVD-HD works well with both Blu Ray and standard DVD, other packages have varying levels of BluRay functionality. More technically-inclined users will of course take the path suggested by ocgw.
I don't know crap about BluRay yet...I just like the thread title...Well Done.
Check this topic
http://forum.videohelp.com/topic369435.html
I faced significant problems just with Close Encounters of the 3rd Kind!
Well you did give good advice for DVD, but then again this is the "blu ray to blu ray" forum lol,......Originally Posted by orsetto
except for 1 thing, while it is true, AnyDVD HD does work w/ DVD and blu ray alike, CloneDVD 2 doesn't work w/ blu ray, but Slysoft is working on a CloneBD that should be released soon
ps. I use DVDFab too, as well as CloneDVD 2
ocgw
thx for the "assist" bro'Originally Posted by fkasparek
ocgw
oops
damn it, i keep typing quote instead od edit
Question - how to make ffmpeg use mjpeg codecs when it encounters 4CC code
By bf4648 in forum Video ConversionReplies: 0Last Post: 12th Oct 2011, 16:53 -
Frustrating issue with Ripbot264
By Beast Lee in forum Blu-ray RippingReplies: 1Last Post: 26th May 2011, 14:55 -
frustrating behavior
By digiflux in forum ffmpegX general discussionReplies: 4Last Post: 5th Oct 2008, 10:16 -
HDV Help, frustrating
By mute- in forum Camcorders (DV/HDV/AVCHD)Replies: 10Last Post: 6th Aug 2008, 04:31 -
Very frustrating TMPgenc problem :(
By love2learn in forum Newbie / General discussionsReplies: 6Last Post: 7th Aug 2007, 00:04
