I've been using MeGUI to try to rip a DVD. I start with the DGIndexer and choose the 6 channel dolby digital stream. It then produces two audio outputs, one that says it has a -16 ms delay, and one that says it has a 0 ms delay. The audio streams are 3 minutes smaller than the video stream.
I've tried muxing with both audio files, and in both of them, the audio isn't synched up correctly, even when I enter the audio delay as -16 ms. The problem seems to arise somewhere in the FBI warnings, but I'm not sure.
Does anybody know if I'm missing some sort of key step? I've had the same problem with multiple DVDs. Thanks in advance for your help.
Results 1 to 1 of 1
meGui final result is out of sync with audio =/
By Chrushev in forum Newbie / General discussionsReplies: 6Last Post: 31st Aug 2010, 21:31 -
Problems with audio sync in MeGUI
By Sutekh in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2009, 15:57 -
Megui audio out of sync
By sat-jokar in forum Video ConversionReplies: 4Last Post: 24th Apr 2009, 23:21 -
MeGUI problems
By src2206 in forum DVD RippingReplies: 2Last Post: 17th Nov 2008, 13:04 -
Audio sync problems/xvid to m2v problems
By dr.gre in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2004, 17:28
