Is there a way to change the grid size in winxp desktop? By changing it both vertically and horizontally would permit more icons to appear on the desktop.
not sure what you mean by "grid size"
the display resolution is a function of the graphics card and your monitor, you cannot display more than the maximum resolution that either allows
if you right click the desktop=>properties=>settings you could play with the settings
you could also use smaller icons and text -
From the Display Properites dialog go to the Appearance tab, press the Advanced button, From the Advanced Appearance dialog, in the Item pulldown select Icon Spacing Horizontal or Icon Spacing Vertical. Go nuts.
Font size will not change size
By pgwillin in forum ffmpegX general discussionReplies: 9Last Post: 8th Jan 2011, 14:04 -
Woopra Desktop Client 1.4 on WinXP
By connorabb in forum ComputerReplies: 5Last Post: 27th Aug 2010, 09:34 -
WinXP Thumbnail Change
By Anakha in forum DVD RippingReplies: 1Last Post: 19th Feb 2010, 10:44 -
HP Slimline computers for video editing VS full size desktop?
By vid83 in forum ComputerReplies: 3Last Post: 9th Feb 2009, 17:26 -
Need to customize desktop icon appearance in WinXP
By alegator in forum ComputerReplies: 3Last Post: 12th Jun 2008, 13:30
