    Hi
    I have this bluray I want to make an mkv out of it, using x264.exe -
    I have made several other backup's like this but this disc is really annoying me.
    copies fine to hdd and I end up with the 20gb m2ts file, I make avs script dont want any resize or any cropping.
    When I start the 1st pass encode the x264.exe sometime runs to 0.6% completion and then just suddently stops, no error given.
    Sometimes I make it to 6.8% and it stops, no error given.
    Does anyone have an idea what the problem could be?
    never happend to me before when making others. I do all the stuff the excat same as I have done before but still it just stops all of the sudden
    Hope someone has some idea's what it could be
    Thanks in advance
    What x264.exe version? Try a different build, some people reported problems with r1251
    oh okay yeah iv been using 1251 but havnt had problem with it other then with this one disc, have made a few others with 1251.
    But i'll try with an older one
  4. Mod Neophyte Super Moderator redwudz's Avatar
    I would try running a memory check. Sudden changes like that may be related to a failed RAM module. Memtest 86 should work for you. http://www.memtest86.com/
    If not, then if it's a newer BD, maybe a decryption problem. I use AnyDVD HD and rip to my HDD for problematic discs. Then use tsMuxeR to select the main video and the desired audio track. I use them for the conversion.
    I've encountered a few BDs that have more than a few problems with the conversions, but none of them have stopped as you describe.
    I have solved my problem, had to index it using VC1 indexer then I can work with it from there..
    Thx for all the input!
    Go ahead delete this thread.
  1. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 1st Dec 2011, 06:10
  2. Replies: 2
    Last Post: 23rd Jun 2009, 11:33
  3. mkv, x264, and h.264 to blu-ray to play on PS3
    By cyberpimp16 in forum Authoring (Blu-ray)
    Last Post: 14th May 2009, 15:58
  4. x264 1080p blu-ray files
    By eric11111 in forum Authoring (Blu-ray)
    Last Post: 7th Dec 2008, 10:48
  5. Blu Ray to MKV (.x264) - What is the compression?
    By james_stewart in forum Blu-ray Ripping
    Last Post: 7th Nov 2008, 06:58
About   Advertise   Forum   RSS Feeds   Statistics   Tools
