hi,
some people on guru3d made an example how to double the fps of an 24p movie to 48 and interpolate frames to do a fluid motion.
http://forums.guru3d.com/showthread.php?t=288017
the results are very impressive. the cpu does do this thing with ffdshow and avisynth script in realtime. for 720p movies its ok but for 1080p the cpu is too slow.
so the idea is to do this job NOT in realtime. i dont know how to do this. i just copied the script and it works. but it would be nice to encode the stream back in to new file and then play normally without that filter. is that possible?
Open your AVS script in a video editor and save a video file.
You probably have to modify that script a bit if you want to use it as an .avs file (i.e. the source filter)
Another way would be to leave everything you have it as ffdshow as the directshow decoder, and use DirectShowSource() in a 1 line .avs script then feed that into an encoder that accepts avs scripts
You should only have to replaceOriginally Posted by poisondeathray
global source=ffdshow_source()
by
source = DirectShowSource(...) # <- add your filename here
(The two 'global's in that script are unnecessary, by the way. Somebody cut and pasted from somewhere else without knowing what they were doing.)
how do you convert m2ts
By Onceler2 in forum Video ConversionReplies: 9Last Post: 8th Dec 2009, 06:12 -
convert m2ts files
By dvd1304 in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2009, 09:10 -
M2TS files - can I convert them ?
By Bansaw in forum Video ConversionReplies: 1Last Post: 10th Dec 2008, 11:32 -
Convert .m2ts?
By Bobd314 in forum Newbie / General discussionsReplies: 9Last Post: 27th May 2007, 03:55 -
Software Frame Interpolation
By DivXExpert in forum EditingReplies: 1Last Post: 19th Aug 2003, 23:37
Statistics
Newest guides
Latest tool updates
New media comments
