Hello,
I am new to the forums and video editing. I recently purchased an Black Magic Intensity Pro and I am trying to record and stream live video using encoder 2. The plan is to capture PC game play and stream it live however I have hooked up the Intensity Card and plugged it in to a 9800GTX gfx card, Cloned the monitors and yet I am not seeing anything show up in encoder 2 I am sure I am missing a setting somewhere so I wanted to see if anyone had any ideas on what could be wrong. There is no documentation with the Capture card to explain set-up this way so I thought I would ask here. Any help would be appreciated.
Thread: Intensity Pro and PC Capture
The Blackmagic cards only record certain resolutions and refresh rates. You need to set your graphics card to output the right format:
http://blackmagic-design.com/product...ity/techspecs/
That would be: 1920x1080i and 1280x720p.HD Format Support 1080i50, 1080i59.94, 720p50 and 720p59.94
Ok I changed my gfx card to 1920 x 1080 and still nothing. Any other ideas?
Ok I found it and set it to 1080i my computer asks if the settings are ok it will stay for a few seconds then it reverts to PC settings at 1920 x 1080 native. Tried this quite a few times. Thanks for the help thus far I am getting there lol.
This is a safety procedure to keep you from setting a resolution/refresh rate your monitor doesn't support -- it would be impossible to go back to the previous setting if you can't see what's on the screen.Originally Posted by Tucker19
The computer changes the resolution to the new setting then asks you to press OK (or something like that) with a dialog box. If you see the dialog and press OK it keeps the new setting. If can't see the dialog (because the setting you chose isn't supported) you can't see the dialog to press OK. After 10 or 15 seconds the resolution is then changed back to the previous setting, saving your ass.
So just press the OK (or whatever) button.
Blackmagic Intensity Pro: Can't capture from any VCR source
By mvrx in forum CapturingReplies: 13Last Post: 2nd Jan 2012, 22:49 -
Black Magic Intensity Pro capture has audio out of sync
By kILLDR3n in forum CapturingReplies: 5Last Post: 20th Jan 2010, 07:43 -
HD Capture from Canon HV-30 to Intensity Pro
By liberty610 in forum CapturingReplies: 18Last Post: 27th Dec 2009, 20:14 -
My Experience: PC to PC 1080i capture using Blackmagic Intensity Pro
By sirsad in forum CapturingReplies: 19Last Post: 2nd Sep 2008, 15:14 -
Intensity Pro Composite capture.
By trydowave in forum CapturingReplies: 0Last Post: 22nd Oct 2007, 19:37
