I am using HDVsplit and followed the instructions exactly. It recognizes the camcorder and I have the output set to HDV
Problem is that the video captured is as if looking through a red lens.
The video when played back on the camcorder is fine though.
I have Win XP SP2
Any ideas?
thanks,
I used VLC to view the captured files (.m2t) and same red tint throughout.
since vls uses it's own codecs to play files i'd guess it's part of the video. if you can cut a sample 40-50 mb and upload it to a file sharing site i'll take a look at it here.
here's a tool that may cut a sample from a big file for you if you need one.
makesample.zip--
HDVsplit makes a bit-identical copy of what is on the tape.
To take an MPEG-2 encoded video, and make it "go all red" would actually take a huge amount of effort - decode, apply colour change, re-encode. That's simply not happening.
It's either a decoding issue, a monitor issue, or a view finder LCD issue.
Cheers,
David.
In the viewfinder LCD it looks fine. I've tried it on 2 different PCs w/2 different monitors.
as 2bdecided said it's in the video then, hdvsplit can't change anything.
try playing the tape from the cam video out port to a tv.--
Thanks for your help. It turns out that the problem was with VLCplayer (or perhaps the PC was overloaded), as I rebooted and previewed it in Sony Vegas and it looked fine.
thx
Canon hv20, 24p hdv, and recommended capture method?
By joshcali in forum Camcorders (DV/HDV/AVCHD)Replies: 24Last Post: 4th Mar 2012, 18:28 -
Firewire capture fom Canon HV20
By johnwc in forum Newbie / General discussionsReplies: 8Last Post: 6th Jul 2010, 09:59 -
Please Urgent Canon HV20 Audio Capture Help
By kadzbiz in forum AudioReplies: 3Last Post: 11th Dec 2007, 02:53 -
Canon HV20 live capture question
By bryant in forum Camcorders (DV/HDV/AVCHD)Replies: 15Last Post: 27th Nov 2007, 11:15 -
Help! Canon HV20 capture problems
By jmunns in forum Camcorders (DV/HDV/AVCHD)Replies: 19Last Post: 21st Nov 2007, 10:16
