I have the following AAC file:
http://www.fileden.com/files/2006/11...98/Channel.aac
But Media Player Classic (Version 6.4.9.0) will not play the file.
However, if you install
Magic AAC to Mp3 Converter 3.7 (install only trial version, no need to pay or register)
http://www.magicvideo.net/aac-to-mp3/
then you can use Media Player Classic to play the above AAC file.
Question: If anybody knows what is the 1 crucial file that allows Media Player Classic to play this AAC file, please tell me. I really don't want Magic AAC to Mp3 Converter on my computer. I only want just the 1 necessary file that allows me to play AAC with Media Player Classic
Results 1 to 10 of 10
I installed this one from Orban some time ago,
http://www.orban.com/plugin/
to listen to a particular streaming radio station that claimed the best audio, which was interesting
That seems to be what plays it for me.
The VCSwap program (lists all codecs) has it on my DirectShow filters list as Orban-CT AAC/aacPlus Stream Parser 1.0.44 - plays MP4/3GP
I am really confused. Please help. I wanted to keep just the necessary files (from Magic AAC to Mp3 Converter) and then delete that software. I went to Program Folders/Magic AAC to Mp3 Converter and carefully deleted (put in Recycle Bin) all the files except those that were necessary to play the AAC file with Media Player Classic. I deleted all the files except 3 files (see screenshot). With just these 3 files, I could still play the AAC file with Media Player Classic. I copied these 3 files into a another folder in Program files, then put all the deleted files back into the Program Folders/Magic AAC to MP3 Converter, then un-installed the Magic AAC to Mp3 Converter software. However, as soon as I un-installed the Magic AAC to Mp3 Converter software, I couldn't play the AAC file any more with Media Player Classic. So there must be some other necessary files that are lurking hidden somewhere else in the computer, but I don't know where. Do you have any idea where these important files might be hidden? I did a search, but couldn't find anything.
[ nevermind ]
EDIT:
jimdagys, thanks a lot for improving the DirectShow structure of my PC.
All you should do is register the .ax file again.
HTH!Code:regsvr32 "path-to\DCBassSource.ax"
OK, looking at your screenshot, it seems there is something(s) in the registry that are necessary and get deleted when I un-install the Magic AAC to Mp3 Converter. Dealing with the "Registry" is not one of my strong points.
What do you mean, I have to
"register the .ax file again."? How do I do that?
And what is this code
(regsvr32 "path-to\DCBassSource.ax"). What do I do with it?
What are the steps (step by step) I need to take to modify the Registry (or the computer) so that I can solve this problem (play AAC file with Media Player Classic after I un-install Magic AAC to Mp3 Converter)? I don't want to install any software, only the necessary few dlls and files that let me play AAC files with Media Player Classic.
When you say
I have no idea what you are talking about. Are you thanking me for something or being sarcastic?jimdagys, thanks a lot for improving the DirectShow structure of my PC.
I really would appreciate if you could help me with this because I feel there is some important computer knowledge that can be learned by solving this problem.
No sarcasm was intended, otherwise I would not have added the
icon.
Actually, before I had read your latest posts, I didn't know that neither ffdshow,
nor CoreAAC, *cannot* decode the so-called "parametric stereo" (read: HE-AAC, v.2)
(whereas foobar2000, Winamp and Mplayer can, indeed).
Now, to make things even simpler: I downloaded the original codec package from the site of
its author ( http://www.dsp-worx.de/?n=15 ), decompressed the .zip archive to the chosen folder,
and double-clicked the file "register.bat".
Again, thanks for helping me to improve my personal knowledge base.
UPDATE:
I've just checked: when inside a MKV container, the stream from the file "Channel.aac"
YES is decoded normally by CoreAAC.
I figured it out. (How to play AAC file with Media Player Classic without installing any software (except a few small files.) Just download this archive:
http://www.fileden.com/files/2006/11.../MPC%20AAC.rar
and put the yellow folder (called MPC AAC) in your Program Files (see screenshot 1). Then just double click on the
register.bat
and you will be able to play the AAC files with Media Player Classic.
Note 0): You can also get these files from: http://www.dsp-worx.de/?n=15
Note 1): If you want to unregister the files, just double click
unregister.bat
Then you won't be able to play the AAC file.
Note 2): If you want to live dangerously, instead of clicking
register.bat
you can do the same thing by using the DOS prompt from Start>Run>Cmd>OK
You must first navigate using DOS commands to the
C:\Program Files\MPC AAC
folder. Then type in
regsvr32 dcbasssource.ax
and press enter. (See screenshot 2.)
If you can figure out and are successful using the DOS prompt, that means that the
register.bat
file is unnecessary and can be deleted. You only really need 3 files:
bass.dll
bass_aac.dll
DCBassSource.ax
Can't play one mp4 file at KMP and Media Player Classic - Home Cinema x64..
By Balema in forum Software PlayingReplies: 5Last Post: 10th Mar 2012, 19:31 -
SOLVED: Media Player Classic and codecs for Easy Subtitles Synchroniser
By bahjan in forum Software PlayingReplies: 0Last Post: 2nd Feb 2012, 12:43 -
How to play CUE in Media PLayer Classic
By lovyagin in forum AudioReplies: 7Last Post: 21st Nov 2009, 00:41 -
Can't play H264 with Media Player Classic
By kruuth in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2008, 17:21 -
Solved: Can't Play WMV in IE with Media Player Classic.
By DarrellS in forum Software PlayingReplies: 0Last Post: 13th May 2008, 11:31
