VideoHelp.com Forum
Results 1 to 10 of 10
    I 08:44:31 ImgBurn Version 2.5.0.0 started!
    I 08:44:31 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 3)
    I 08:44:31 Total Physical Memory: 2,096,172 KB - Available: 1,048,672 KB
    I 08:44:31 Initialising SPTI...
    I 08:44:31 Searching for SCSI / ATAPI devices...
    I 08:44:31 Found 1 DVD±RW/RAM and 1 BD-RE!
    I 08:44:48 Operation Started!
    I 08:44:48 Source File: C:\Documents and Settings\LEE\Desktop\die hard.mds
    I 08:44:48 Source File Sectors: 11,529,920 (MODE1/2048)
    I 08:44:48 Source File Size: 23,613,276,160 bytes
    I 08:44:48 Source File Volume Identifier: LIVE_FREE_DIE_HARD
    I 08:44:48 Source File Volume Set Identifier: 3AD6A24600AFEE50
    I 08:44:48 Source File Application Identifier: ImgBurn v2.4.4.0
    I 08:44:48 Source File Implementation Identifier: ImgBurn
    I 08:44:48 Source File File System(s): UDF (2.50)
    I 08:44:48 Destination Device: [1:0:0] HL-DT-ST BD-RE GBW-H20L YG01 (F (ATA)
    I 08:44:48 Destination Media Type: BD-R (Disc ID: SONY-NN3-02) (Speeds: 2x)
    I 08:44:48 Destination Media Sectors: 12,219,392
    I 08:44:48 Write Mode: BD
    I 08:44:48 Write Type: DAO
    I 08:44:48 Write Speed: MAX
    I 08:44:48 BD-R Verify Not Required: Yes
    I 08:44:48 Link Size: Auto
    I 08:44:48 Lock Volume: Yes
    I 08:44:48 Test Mode: No
    I 08:44:48 OPC: No
    I 08:44:48 BURN-Proof: Enabled
    I 08:45:04 Filling Buffer... (40 MB)
    I 08:45:05 Writing LeadIn...
    W 08:45:05 Failed to Write Sectors 32 - 63 - Reason: Write Error
    W 08:45:05 Retrying (1 of 20)...
    W 08:45:05 Retry Failed - Reason: Invalid Address For Write
    W 08:45:05 Retrying (2 of 20)...
    W 08:45:05 Retrying (3 of 20)...
    W 08:45:05 Retrying (4 of 20)...
    W 08:45:05 Retrying (5 of 20)...
    W 08:45:05 Retrying (6 of 20)...
    W 08:45:05 Retrying (7 of 20)...
    W 08:45:06 Retry Failed - Reason: Invalid Address For Write
    W 08:45:06 Retrying (8 of 20)...
    W 08:45:06 Retrying (9 of 20)...
    W 08:45:06 Retrying (10 of 20)...
    W 08:45:06 Retrying (11 of 20)...
    W 08:45:06 Retrying (12 of 20)...
    W 08:45:06 Retrying (13 of 20)...
    W 08:45:06 Retrying (14 of 20)...
    W 08:45:06 Retrying (15 of 20)...
    W 08:45:06 Retrying (16 of 20)...
    W 08:45:06 Retrying (17 of 20)...
    W 08:45:06 Retrying (18 of 20)...
    W 08:45:06 Retrying (19 of 20)...
    W 08:45:06 Retrying (20 of 20)...
    E 08:45:07 Failed to Write Sectors 32 - 63 - Reason: Write Error
    E 08:45:07 Next Writable Address: 0
    I 08:45:07 Synchronising Cache...
    W 08:45:08 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Write Error
    W 08:45:08 Synchronise Cache Failed! - Reason: Write Error
    W 08:45:08 Retrying (1 of 3)...
    W 08:45:09 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Write Error
    W 08:45:10 Retry Failed - Reason: Write Error
    W 08:45:10 Retrying (2 of 3)...
    W 08:45:11 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Write Error
    W 08:45:11 Retry Failed - Reason: Write Error
    W 08:45:11 Retrying (3 of 3)...
    W 08:45:12 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Write Error
    W 08:45:12 Retry Failed - Reason: Write Error
    E 08:45:13 Synchronise Cache Failed! - Reason: Write Error
    I 08:45:13 Synchronising Cache (Last Attempt!)...
    E 08:45:13 Synchronise Cache Failed! - Reason: Unknown (ASC: 0xA0, ASCQ: 0x80)
    W 08:45:14 User opted to skip the 'Close Track/Session/Disc' functions.
    E 08:45:14 Failed to Write Image!
    E 08:45:14 Operation Failed! - Duration: 00:00:26
    I 08:45:14 Average Write Rate: 0 KB/s (0.0x) - Maximum Write Rate: 0 KB/s (0.0x)
  2. Member hech54's Avatar
    Since you used ImgBurn....it MUST be crappy BluRay discs.
    so you think its the blank media causing the problem? If so that means i just wasting money on a dud disc.
  4. Member hech54's Avatar
    That's why I don't do BluRay.....yet. Too expensive and there is not enough of a "database" of who makes good discs and bad discs.
  5. Member Abas-Avara's Avatar
    Sometimes I had to format an already blank DVD cause I had errors with burning.
    The flag once raised will never fall!
  6. Member bendixG15's Avatar
    Well - whose disks did you use ???
  7. That drive is basically the same as the GGW-H20L and that has a newer firmware with better support for BD-R media.
    If you fancy it, crossflash it as per here:
    http://club.cdfreaks.com/f142/lg-blu...06lu11-260811/
  8. I use this media and have yet to burn a coaster. I have burnt 85 of these discs so far.
    I don't think this is a media problem, I have a 100 of these disks and have burned 50 or more succesfully.
    What did hape is my computer crashed and I had to reinstall every thing since then I am unable to burn a DVD
    It fails trying to write leadin with the Failed to write sectors 32 -63
    Can't figure this out
    I 10:11:13 ImgBurn Version 2.4.2.0 started!
    I 10:11:13 Microsoft Windows Vista Business Edition (6.0, Build 6001 : Service Pack 1)
    I 10:11:13 Total Physical Memory: 3,656,704 KB - Available: 2,409,292 KB
    I 10:11:14 Initialising SPTI...
    I 10:11:14 Searching for SCSI / ATAPI devices...
    I 10:11:15 Found 1 DVD±RW/RAM!
    I 10:11:28 Operation Started!
    I 10:11:28 Source File: C:\Users\morry\Documents\INVITUS.ISO
    I 10:11:28 Source File Sectors: 2,262,656 (MODE1/2048)
    I 10:11:28 Source File Size: 4,633,919,488 bytes
    I 10:11:28 Source File Volume Identifier: Invictus
    I 10:11:28 Source File Volume Set Identifier: 3C28A89500228665
    I 10:11:28 Source File Application Identifier: IMGBURN V2.4.2.0 - THE ULTIMATE IMAGE BURNER!
    I 10:11:28 Source File Implementation Identifier: ImgBurn
    I 10:11:28 Source File File System(s): ISO9660, UDF (1.02)
    I 10:11:28 Destination Device: [0:1:0] PLDS DVD+-RW DU-8A2S 4D12 (E (ATAPI)
    I 10:11:28 Destination Media Type: DVD-R (Disc ID: CMC MAG. AM3) (Speeds: 2x, 4x, 6x, 8x)
    I 10:11:28 Destination Media Sectors: 2,298,496
    I 10:11:28 Write Mode: DVD
    I 10:11:28 Write Type: DAO
    I 10:11:28 Write Speed: MAX
    I 10:11:28 Link Size: Auto
    I 10:11:28 Test Mode: No
    I 10:11:28 OPC: No
    I 10:11:28 BURN-Proof: Enabled
    I 10:11:29 Filling Buffer... (40 MB)
    I 10:11:29 Writing LeadIn...
    W 10:11:44 Failed to Write Sectors 32 - 63 - Reason: Invalid Address For Write
    W 10:11:44 Retrying (1 of 20)...
    W 10:11:44 Retry Failed - Reason: Invalid Address For Write
    W 10:11:44 Retrying (2 of 20)...
    W 10:11:44 Retrying (3 of 20)...
    W 10:11:44 Retrying (4 of 20)...
    W 10:11:44 Retrying (5 of 20)...
    W 10:11:44 Retrying (6 of 20)...
    W 10:11:44 Retrying (7 of 20)...
    W 10:11:44 Retrying (8 of 20)...
    W 10:11:44 Retrying (9 of 20)...
    W 10:11:44 Retrying (10 of 20)...
    W 10:11:44 Retrying (11 of 20)...
    W 10:11:44 Retrying (12 of 20)...
    W 10:11:44 Retrying (13 of 20)...
    W 10:11:44 Retrying (14 of 20)...
    W 10:11:44 Retrying (15 of 20)...
    W 10:11:44 Retrying (16 of 20)...
    W 10:11:44 Retrying (17 of 20)...
    W 10:11:44 Retrying (18 of 20)...
    W 10:11:44 Retrying (19 of 20)...
    W 10:11:44 Retrying (20 of 20)...
    E 10:12:12 Failed to Write Sectors 32 - 63 - Reason: Invalid Address For Write
    E 10:12:12 Next Writable Address: 0
    I 10:12:12 Synchronising Cache...
    W 10:12:17 User opted to skip the 'Close Track/Session/Disc' functions.
    E 10:12:17 Failed to Write Image!
    E 10:12:17 Operation Failed! - Duration: 00:00:49
    I 10:12:17 Average Write Rate: 0 KB/s (0.0x) - Maximum Write Rate: 0 KB/s (0.0x)
  10. Originally Posted by scoooter1
    Well seeing that INVITUS is not out on dvd yet, this must be a pirated copy. So, that's probably why your computer crashed and now has problems.
    Illegal downloads=problems.
  1. Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
    By brad350 in forum Newbie / General discussions
    Last Post: 21st Apr 2012, 04:15
  2. New to Blu Ray burning
    By bryankendall in forum Blu-ray Ripping
    Last Post: 28th Aug 2010, 17:31
  3. blu-ray burning
    By ttheb1 in forum Authoring (Blu-ray)
    Last Post: 14th Jun 2010, 03:58
  4. Burning Blu Ray from ripped Blu Ray
    By ppurdue in forum Blu-ray Ripping
    Last Post: 15th Oct 2008, 19:51
  5. Replies: 5
    Last Post: 5th May 2008, 16:05
