VideoHelp.com Forum
    Hello we captured footage with the Sony Hardrive based Camcorder, transfered the video files onto an external drive. We're now trying to import those MPG files into Final Cut Pro 6.0.5 but it seems audio is not supported. We played in Quicktime and Finalcut, no audio, but audio works in VLC.
    Are we missing codecs?
    Any suggestions?
  2. Originally Posted by Benhermies
    any missing features inside QuickTime
    Any suggestions?
    Try MPegStreamClip
    bye
    Some drawings ? http://www.whynotflores.com/. A software for DV, DVD-Video, HD files (AVCHD/…): http://www.movieconverter-studio.com/ 1.6 (2010/08)
    Hey mate, I am having the exact same problem. Did you end up solving it? Help me.
  4. Member edDV's Avatar
    Try importing the original SD card to iMovie. Capture to AIC then import that to FCP.
    http://www.kiva.org/about
  1. Replies: 8
    Last Post: 30th Sep 2011, 14:26
  2. From 8mm tape to Final Cut...no camcorder
    By cecile in forum Capturing
    Last Post: 23rd Aug 2011, 22:53
  3. Import Panasonic Mini-DV camcorder files to Final Cut Express?
    By benalen01 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 15th Mar 2010, 02:04
  4. Final Cut Pro imports .MPG's with no audio.
    By Benhermies in forum Mac
    Last Post: 20th Sep 2009, 16:09
  5. Final Cut 5 codec missing
    By kippard in forum Mac
    Last Post: 6th Jul 2008, 11:17
