I need to split a mpg file into separate files. Will there be any re-encoding if I use mpg2cut2 to do this? I am looking to avoid any quality loss. Can MPEG streamclip split a mpg file into separate files?
Results 1 to 14 of 14
Thanks. Can I split by typing the numbers from 2.50 to 4.30, or is it all cursor based?
Not that I know of. And keep in mind that it only cuts on keyframes.Originally Posted by bz186
Highly compressed video files like MPG files get a lot of their compression from only encoding the changes from frame to frame. Every now and then a frame is compressed as a complete image, much like a JPEG image, this is called a keyframe. Then there are a bunch of frames that encode only the frame to frame changes. So, for example, a talking head shot with a static background only has to include the moving lips and head of the talker for most of the frames. The Group Of Frames from one keyframe to the next is called a GOP. DVD compatible MPEG 2 has is a keyframe about every half second.
Mpeg2cut2 only allows cuts on keyframes. It only allows you to mark-in and mark-out on keyframes. It only stops on keyframes when you move the slider or use the arrow keys. -
Thank you for explaining keyframe. I will go ahead and download the software.
Cuttermaran also does smart rendering (can cut on any frame), and is free.
Yes it can. Read the documentation on the MPEG streamclip website to learn how to do this. I'll give you a clue for working with video from your camera. If there are timecode breaks they correspond to the end of a recording session. However, MPEG Streamclip cuts on keyframes like most other free editing tools.Originally Posted by bz186
Strange... I use Cuttermaran most of the time, but I work exclusively with NTSC recordings from my DVD recorder. I have demuxed using Rejig, VOBEdit, and MPEG Streamclip, and rarely have a problem with synchronization, mostly when VRO files are the source. Cuttermaran requires demultiplexed sources, but the free authoring program that I use works best with those too, so it is not an inconvenience for me.Originally Posted by sambat -
I haven't used it on a recording, but I shall make one and try it.Originally Posted by usually_quiet
I made a short recording and the there was no problem cutting the clip - so my recordings or PAL movies work ok.
I normally clip parts from movie DVDs and nothing will get them in sync - adjusting the delay in Cuttermaran has no discernible affect.
All the movies are NTSC using pulldown.
Edit:
I decided to remove the pulldown (using DGPulldown; set in and out at 23.976) - I could then set/adjust the audio delay in Cuttermaran and got a good synced output.
Converting an MPG file to an ISO file.
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Dec 2009, 21:58 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
