hi everybody!
i've edited a video in FCP (for there you know i'm using MAC) in HD with 30fps (i filmed on the canon 5D which makes 30fps not th usual 29.97...). i exported the clip to a quicktime with animation codec and put this into ffmpeg.
mp4 with H264 (x264)
the result is not what i expected: the colors are darker and audio seems to run out of sync. the information-window in quicktime, says that the file-framerate ist 29.97 which could explain, why things are running out of sync. but i set the framerate zu 30fps...
i also thought of using the command-line-version but i am not that computer-guy to handle so much options... ;-((
can anybody help?
Thread: problems with sync
Moving you to our Mac section.
You can also try convert to mp4 h264 using handbrake, mpeg streamclip or avidemux. All FREE.
tanks for the reply. of course, there are many converters for mp4 but in the past i had the best results regarding datarate vs. quality with ffmpeg - but sadly these projekct were in sync becaus of pal-stadtard (25fps)...
The darkness is a known issue with ffmpeg conversion. When I use MPEG Streamclip, I sometimes use the tools it provides in its MP4/H264 conversion window to brighten the video about 10% and add 20% to the saturation. YMMV.
i've tried that too, but hey: i'm not doing my color correction with state of the art-tools to deliver a file, with some vague corrections in the end...
any idea of the not-in-sync-cause?
As Baldrick has mentioned, Handbrake might do the job. I use it and haven't found the same darkness issues. It also seems to do a proper job of AV sync.
Audio Sync Problems
By nephesh in forum Video StreamingReplies: 0Last Post: 12th May 2011, 08:10 -
Need help with sync problems during processing
By Jon.G in forum Authoring (DVD)Replies: 23Last Post: 6th May 2011, 04:14 -
Problems with voices out of sync
By Jimbo1 in forum Video ConversionReplies: 4Last Post: 25th Apr 2011, 05:32 -
A/V sync problems with an AVI...
By takearushfan in forum Video ConversionReplies: 0Last Post: 17th Aug 2010, 17:41 -
Time sync problems.
By Poppa_Meth in forum ComputerReplies: 9Last Post: 1st Sep 2007, 00:30
