VideoHelp.com Forum
    Vob2Mpg produces an mpeg2 file that contains the subtitles.
    Using Mpeg2Cut2, the parts I need can be saved and joined as one and the subtitles are still there - but the file cannot be re-authored to DVD format with the subtitles..
    VLC knows the subs exist in the mpeg files and plays them, but there seems to be no way extract them.
    Instead I used DVD Shrink to select the parts I needed - but they are separate titles and playback isn't smooth.
    I thought I could then convert the subs to sub/idx format and join them using VobSub Joiner.
    It has a problem joining them, inasmuch as the times listed for the subs are the original times from the movie - they don't correspond to the actual length of the new clip.
    Using SubResync I could guess the real start times for the subtitles, but it's tedious work.
    What I need is a way of either extracting the subs from the mpeg files or a way of joining the subs (with the correct times) from DVD Shrinks output.
    Moving you to our subtitle section.
    I would....hmm....give up...
    Found that CLI Eac3To can de-mux an mpeg-2 file (including subtitles) and the times reflect the running time of the clip (not the original times from the movie).
    And VobSub Joiner works ok now.
    eac3to -demux filename.mpg
  1. Replies: 15
    Last Post: 26th May 2010, 06:45
  2. DTS audio time not correct
    By anfield7 in forum Newbie / General discussions
    Last Post: 6th Mar 2009, 10:31
  3. Settings Correct? Taking a Long Time/.avi to DVD
    By 5Buffalo in forum ffmpegX general discussion
    Last Post: 24th Dec 2008, 14:29
  4. Replies: 9
    Last Post: 2nd Aug 2008, 18:02
  5. Clock will not stay set to correct time
    By driley in forum DVD & Blu-ray Recorders
    Last Post: 28th Mar 2008, 00:20
